Go to Post Engineering is a big, big type of fishing to teach. Inspiring kids to study it in college might be more practical. - connor.worley [more]
Unread 13-02-2011, 14:22
Valencia Valencia is offline
FRC #3705
Valencia is an unknown quantity at this point
How to setup the Victor Fans
I'm just wondering where do red and blue wires connect to the digital side cart.
Unread 13-02-2011, 14:27
PatrickBrew1086's Avatar
PatrickBrew1086 PatrickBrew1086 is offline
FRC #0401 (Copperhead Robotics)
PatrickBrew1086 will become famous soon enoughPatrickBrew1086 will become famous soon enough
Re: How to setup the Victor Fans
It is actually a little simpler than that! All you have to do is put the red fan wire on the same screw as the red input wire (the one that goes into the Power Distribution Board) and the blue fan wire on the same screw as the black input wire. Hope this helps!
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
The most common way to wire the Victor fan connections is to wire them directly to the V+ and V- input terminals of the Victor. This way, whenever the Victor has power, the fan will be on.
Unread 13-02-2011, 17:02
Valencia,
I recommend you wire the fans directly to the power input on the Victor. If you check the KOP page on the First website there are links to the installation and operations documents for the Victor speed controllers.
Unread 14-02-2011, 13:42
Slothbron's Avatar
Slothbron Slothbron is offline
AKA: Nathan
FRC #3216 (Missoula Robotics Team)
Slothbron is an unknown quantity at this point
Last year when we used the victor speed controls we did not use the fans. But we where only using it to control a small motor. I do not recommend doing this if you are using larger motors like the drive motors or the bigger bane bot motors.
MRT 3216
2010- Salt lake City Highest Rookie Team seed
Unread 14-02-2011, 14:56
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
I'm curious as to why you would do this?
I can't think of any situation where it would be a good idea, the fans use a negligible amount of power, and power FETs can actually heat up quite rapidly if your motor stalls, even momentarily by accident.
Actually, I've never looked in the rules regarding this particular configuration, is there anything in the rules forbidding a fanless speed controller, or is it just not a good idea?
Matt
Matt Krass
Unread 14-02-2011, 15:02
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Matt
Surprisingly, this was the only thing I was able to find in reference to the fans was this clause:
D. The supplied fans attached to speed controllers may be powered from the power input
terminals.
It doesn't seem that there is anything in the manual that mandates the use of the fans on the speed controllers - not that I would recommend not using them.
-Dustin Benedict
Unread 14-02-2011, 15:29
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Using Victors without the fans is popular among combat robotics.
Art Dutra IV
世上无难事,只怕有心人.
Unread 14-02-2011, 16:31
The manufacturer says the fans need to be in place and First supports the manufacturer on this point. Victors must have fans.
From the 884 User's Manual...
1. The fan must be wired so it is always ON when the
Victor is ON.
If you did not have fans on your Victors in the past, consider yourself lucky.
