signals
can we put signals in the robot for the 2011 game
Re: signals
What do you mean by signals?
Turn Signals? Position Signal lights? Hands to Hand Signal with? |
Re: signals
signals that could tell the human player what tube to put out.
Re: signals
Assuming that no other rules are broken in the process, then it's perfectly legal to build and use a Human Player Signalling device on your robot. Our team is using an array of LEDs and so are many others.
Re: signals
I gather that a spike relay must be used to interface each signal light. That would be 3 spikes to cover the 3 logos.
Any other options? |
Re: signals
Program one spike to control two LEDs which would mean you need two spikes.
#7
Re: signals
I also believe you are able to use the Digital and analog outputs for this purpose |
#8
Re: signals
Re: signals
http://www.chiefdelphi.com/media/photos/36358
A "simple" idea using some 12v bulbs, a cheap flashlight housing and reflector, and a servo with some lexan attached to it. One could also just make some non-powered "flags" and attach them to the servo as well, have em poke through your bodywork or whatnot. |
#10
Re: signals
Were making led boards and putting pwm's on them and plugging them in to a digi sidecar
#11
Re: signals
Another option is this handy signalling light from AndyMark available 3/4
http://www.andymark.com/ProductDetai...ctCode=am-0897 It uses a spike relay to control the LEDs |
