Go to Post We need to start building FIRST competition arenas and leasing them in the off-season to the sports teams and conventions ;) - protoserge [more]
Unread 15-02-2011, 18:32
3p1c w1n 3p1c w1n is offline
FRC #1529
3p1c w1n is an unknown quantity at this point
Autonomous Problem saving power values
When opening the Autonomous vi front panel by default all the values are negative. I change them to positive values and run the program on the robot and it works flawlessly. Then I attempt to save it, but it always goes back to the negative. How do you change and save those values?
~Team 1529 Cybercards~
Unread 15-02-2011, 18:33
Re: Autonomous Problem saving power values
After you've entered the new value, right-click on the control, select data operations then select make current value default.
Unread 15-02-2011, 18:34
To save all the front panel values, click "Edit -> Make Current Values Default"
To save only one of the front panel values, right click on it and go "Data Operations -> Make Current Value Default"
Unread 15-02-2011, 19:06
FRC #1529
Thank you!!
