Go to Post Maybe you should whack it a few times with a hammer. That always seems to fix our robots. - Adam Y. [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 18-02-2011, 16:38
BrandonQ BrandonQ is offline
FRC #3171
BrandonQ is an unknown quantity at this point
Few Tetrix/Minibot q's
Figured I'd post here since they're three questions, and it -is- part of a kit...
But anyways, since we need a few parts
1) Where can you buy the extra Tetrix parts from? Is the only location the Lego one, or are there other stores?
2) How long do you figure they take to ship to NY
3) In the rules, by "identical battery", what exactly are they referring to? Same size/weight, same voltage/capacity/type(NiMh), etc...?
Unread 18-02-2011, 16:42
EthanMiller EthanMiller is offline
Lead Programmer
AKA: Socks
FTC #4356 (The Zip Ties)
EthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura about
Re: Few Tetrix/Minibot q's
1) If you've got an FTC team, parts.ftcrobots.com is the cheapest I've found, though it's still Lego. You can also try Pitsco for parts.
2) Our orders usually take about two weeks.
I'll let someone else get 3, we could only do FTC this year ( ).
When all else fails, read the manual.
FRC 1713 K Island Gears 2009, 2010 (Not 2011 due to budget, hopefully 2012!) - Fingerlakes Regional
FTC 4356 The Zip Ties 2010-2011 Season - NNYRC (2010 9th seed).
Unread 18-02-2011, 19:39
Techhexium Techhexium is offline
FTC #3555
Techhexium has a spectacular aura aboutTechhexium has a spectacular aura about
1)For FRC Teams, there is a promo code that has a 30% discount. You buy Tetrix parts at the Lego Store.
FTC teams can go to the website EthanMiller already pointed out and when you prove that you're an FTC team you'll get the same discount.
2)10 business days, usually two weeks.
3)Identical battery meaning the battery must be the same battery used in FTC. It's a NiMH 10-cell batttery, it comes in black with a warning sticker(starting in late 2010), and red and blue (before late 2010) and says 'Orion 3000' on the sides. It has 20A fuses.
Unread 28-02-2011, 00:28
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
3) Same part number, same manufacturer.
