Changing DIO Module in Dashboard?
I'm making a custom Dashboard, and everything is done except the display of our DIO Module on the Dashboard. We're using slot 6 instead of the default slot 4, and I can't find a way to select it anywhere in the VIs. Where can I change which slot is displayed?
Re: Changing DIO Module in Dashboard?
Nevermind. I didn't see that there were two Parse Digital Module VIs.
Instead, or in addition to?
<R54> B. The Digitial Sidecar must be connected to a NI 9403 module in Slot 4 of the cRIO-FRC. |
By default, the Build Dashboard Data VI only returns the channels for slot four. You can turn the other one on by opening the VI and changing the front panel selectors and making current value default. As Alan asked, is this because you need another, or is it a problem with slot 4?
Greg McKaskle |
