Go to Post And who is to say what is the mean? Do I mean the mean? Or even the average? Or am I just being mean (or average, which could be my mean)? - dlavery [more]
Unread 20-02-2011, 17:25
Pat_Cunningham Pat_Cunningham is offline
FRC #0178
Pat_Cunningham is an unknown quantity at this point
Encoder problems
Hello,
We are having an issue which the code says that there is already something on "Slot 4 Channel 4" whenever I use the encoders. But the problem is that our encoder isn't on "Slot 4 Channel 4" and it doesn't matter if there is something in "Slot 4 Channel 4" or not it throws that error.
Thanks,
Pat Cunningham
Unread 20-02-2011, 17:54
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
Re: Encoder problems
Do you assign two sensors to the same channel? Thats what I've seen cause that error.
Unread 20-02-2011, 18:49
Amanda_Theilman Amanda_Theilman is offline
FRC #0178
Amanda_Theilman is an unknown quantity at this point
I'm also from team 178, and no, we did not have two sensors plugged into the same port - we checked that already.
Unread 20-02-2011, 19:07
ArchVince's Avatar
ArchVince ArchVince is offline
FRC #1290 (Si Se Puede)
ArchVince will become famous soon enough
No, that isn't what he meant. If you accidentally assigned two to the same port in your code, that's when the error would arise.
PETA wants your help finding Schrödinger.
Unread 20-02-2011, 19:10
FRC #0178
The code only has one pointer to slot 4 channel 4
Unread 20-02-2011, 20:18
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
I'm 99% sure the code defaults to slot 4, so if your code has anything like this:
Servo/Victor/Whatever object = new Blah(4);
Would also produce the same error, whether you're including the slot argument or not.
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 21-02-2011, 00:35
ArchVince's Avatar
To be able to help you further I'd need to see your code.
