Go to Post I can attest that mentoring is probably the most important aspect of this program. - Tom Bottiglieri [more]
Unread 20-02-2011, 18:31
quinxorin quinxorin is offline
Mentor now :(
AKA: Ian Pudney
quinxorin will become famous soon enough
Loud planetary gearbox - Help
Our team just got our RS-550 26:1 P60 planetary gearboxes from BaneBots. After greasing and reassembling them, they seemed significantly louder than similar gearboxes we used in 2009. Is this normal? If not, how much grease should there be? We use white lithium.
"Sed res docuit id verum esse, quod in carminibus Appius ait, fabrum esse suae quemque fortunae."
- Every man is the architect of his own fortune.
Unread 20-02-2011, 18:45
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Loud planetary gearbox - Help
It doesn't take a lot of grease to lubricate the gearbox. Adding more probably won't make the noise change noticeably. Can you post a video of the motor/gearbox running (with sound), both without load and under load?
Unread 20-02-2011, 18:52
Mentor now :(
AKA: Ian Pudney
Sure, I'll do it tomorrow (school rules prohibit us from working on Sunday, or that's what I'd be doing right now).
Unread 20-02-2011, 22:38
Captaindan's Avatar
Captaindan Captaindan is offline
AKA: Daniel
FRC #0364 (Team Fusion)
Team Role: Driver
Captaindan is a jewel in the roughCaptaindan is a jewel in the roughCaptaindan is a jewel in the roughCaptaindan is a jewel in the rough
ours are loud too so is that bane bot motor it screams similarly to a dentist drill
