Go to Post You are joining the greatest family in the world, FIRST, because we all strive to practice GP. - Ken Loyd [more]
Unread 21-02-2011, 17:41
Spartechs2441's Avatar
Spartechs2441 Spartechs2441 is offline
AKA: Calvin Chang
FRC #2441 (Maryknoll Spartechs)
Spartechs2441 is an unknown quantity at this point
Compressor isnt running!
The wire is correct, and I'm pretty sure the programming is right.
I used the Labview Compressor example code, and it still didn't run.
I searched the forums and i couldn't find anything to fix our problem
Last minute problems suck
Begin.vi
Teleop.vi
Unread 21-02-2011, 17:44
Timz3082 Timz3082 is offline
FRC #3082 (Chicken Bot Pie)
Timz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the rough
Re: Compressor isnt running!
I don't believe there is a need to have the compressor portion in teleop all you need is to have the close compressor in the end vi... and the pressure switch also needs to be hooked up sig to ground.
Unread 21-02-2011, 18:08
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
All you need is the open compressor and start compressor. This will allow the compressors vi run all the time the robot is running enabled.
Unread 21-02-2011, 19:12
AKA: Calvin Chang
so is this correct?
begin.vi
finish.vi
Unread 21-02-2011, 19:30
Originally Posted by Spartechs2441 View Post
so is this correct?
begin.vi
finish.vi
This is what it should be:
Unread 21-02-2011, 22:22
AKA: Calvin Chang
the compressor ran the first time we tried, but now it doesn't
i don't see anything that changed in the wiring, so i don't know what the problem could be
we're all crying in the fetal position, and you're our only hope
wiring:
PDB>spike>compressor
spike>relay 1
pressure switch> DIO 1
Oh, and are the window motors strong?
Unread 21-02-2011, 22:44
wiring:
spike>relay 1
you do not need to stop the compressor unless you have written your own code, just wire the error out together for all of them and you should be good. (the stop vi could be your issue)
Window motors are surprisingly weak compared to the other motors, but they can work in a pinch, all you need to do is remove the locking pins(which is allowed in the rules)(do a search to find out how) and they should be able to do quite a bit, but they do however lock up when they overheat.
Unread 21-02-2011, 22:47
seannoseworthy's Avatar
seannoseworthy seannoseworthy is offline
FRC #2200 (MMRambotics)
seannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to behold
Send a message via MSN to seannoseworthy
If your sure of the programming, wiring and if it has run once i would check the fuse in the spike next.
Unread 21-02-2011, 22:48
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
We have had a lot of problems with the fuse on the spike I would check that
Expect the best, Prepare for the worst
Unread 21-02-2011, 22:53
indubitably's Avatar
indubitably indubitably is offline
AKA: Ryan Guinn
FRC #2338 (Gear It Forward), FRC #1732 (Hilltoppers)
indubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond repute
Look on the actual breakout board, if both the green and red leds are not lighting up, I know your problem.
You have to open the open compressor file, open up the static vi reference and change where it says Forward to On.
This fixed our compressor problem
FRC 1732 (Hilltoppers): Mentor
FRC 2338 (Gear It Forward): Mentor/Alumnus
FRC 4096 (CTRL-Z): Mentor
Unread 21-02-2011, 23:00
AKA: Calvin Chang
I did a search and just got results from chief delphi of people saying to remove the locking pins, can you explain or link to a how-to?
Unread 21-02-2011, 23:33
Here is a good tutorial http://wiki.team1640.com/index.php?t...r_Locking_Pins
Did you get the compressor working? I hope I have been of some help at least
Unread 22-02-2011, 02:29
AKA: Calvin Chang
Yeah, the compressor ran, but now we couldn't figure out how to activate the solenoids and stop the air from pumping to the pneumatic pistons
You all were a great help, thanks
robot is in the crate for shipping, and we're hoping to figure out whats going on before the competition
Unread 22-02-2011, 07:26
Someone told me there was food here
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
With a standard solenoid setup (at least ours) air will always be in the actuators. Its just a matter of is it pushing the actuator out or is it pulling it in. It is possible to set it up to not do that, but I don't think I've ever seen it.
