My team is scrambling to create a working autonomous.
Our code, so far, is a modified version of the Java sample line tracker. We had to change our code to work off of two sensors because, unfortunately, one of our three line sensors came broken. We understand that all the sample code does is move the robot forward for 8 seconds, but even with this sample code loaded on the robot, our robot does zilch. We're just trying to get our robot to show some sign of life while put in autonomous mode. Can anybody help us out? All suggestions are appreciated. Here's what we have loaded, autonomous-wise: Code:
public void autonomous() {
getWatchdog().setEnabled(false);
getWatchdog().feed();
//Timer.reset(); //Resets the timer
//Timer.start(); //Starts the timer
int binaryValue;
int previousValue = 0; // the binary value from the previous loop
double steeringGain; // the amount of steering correction to apply
// the power profiles for the straight and forked robot path. They are
// different to let the robot drive more slowly as the robot approaches
// the fork on the forked line case.
double forkProfile[] = {0.70, 0.70, 0.55, 0.60, 0.60, 0.50, 0.40, 0.00};
double straightProfile[] = {0.7, 0.7, 0.6, 0.6, 0.35, 0.35, 0.35, 0.0};
double powerProfile[]; // the selected power profile
// set the straightLine and left-right variables depending on chosen path
boolean straightLine = ds.getDigitalIn(1);
powerProfile = (straightLine) ? straightProfile : forkProfile;
double stopTime = (straightLine) ? 2.0 : 4.0; // when the robot should look for end
boolean goLeft = !ds.getDigitalIn(2) && !straightLine;
System.out.println("StraightLine: " + straightLine);
System.out.println("GoingLeft: " + goLeft);
boolean atCross = false; // if robot has arrived at end
// time the path over the line
Timer timer = new Timer();
timer.start();
timer.reset();
int oldTimeInSeconds = -1;
double time;
double speed, turn;
// loop until robot reaches "T" at end or 8 seconds has past
while ((time = timer.get()) < 8.0 && !atCross) {
int timeInSeconds = (int) time;
// read the sensors
int leftValue = left.get() ? 1 : 0;
//int middleValue = middle.get() ? 1 : 0;
int rightValue = right.get() ? 1 : 0;
// compute the single value from the 3 sensors. Notice that the bits
// for the outside sensors are flipped depending on left or right
// fork. Also the sign of the steering direction is different for left/right.
if (goLeft) {
binaryValue = leftValue * 4 + rightValue;
steeringGain = -defaultSteeringGain;
} else {
binaryValue = rightValue * 4 + leftValue;
steeringGain = defaultSteeringGain;
// get the default speed and turn rate at this time
speed = powerProfile[timeInSeconds];
turn = 0;
// different cases for different line tracking sensor readings
switch (binaryValue) {
case 1: // on line edge
turn = 0;
break;
case 5: // all sensors on (maybe at cross)
if (time > stopTime) {
atCross = true;
speed = 0;
break;
case 0: // all sensors off
if (previousValue == 0 || previousValue == 1) {
turn = steeringGain;
} else {
turn = -steeringGain;
break;
default: // all other cases
// print current status for debugging
if (binaryValue != previousValue) {
System.out.println("Time: " + time + " Sensor: " + binaryValue + " speed: " + speed + " turn: " + turn + " atCross: " + atCross);
// set the robot speed and direction
robotDrive.arcadeDrive(speed, turn);
if (binaryValue != 0) {
previousValue = binaryValue;
oldTimeInSeconds = timeInSeconds;
Timer.delay(0.01);
// Done with loop - stop the robot. Robot ought to be at the end of the line
robotDrive.drive(0,0);
Re: Last minute autonomous help
You say two? Good luck with that, it can be done, but you will require either gyros or encoders. Keep a record of the speeds, or the angle it has veered off to. Mount a line tracker in the front, and the other one in the back so it always is triggered. Do some calculations. I too have to work on the autonomy. I will be writing my own from scratch.
We don't use line tracking, we use encoders we drive a fixed distance straight and place a piece.
Since you're running so late. try code that powers your drive forward at say 1/3 power for 5 seconds. Tune it until it just bumps the wall and then place a piece. Make sure you keep a good battery, but I think that's your best bet for a last minute autonomous BEFORE you ship. Alternatively, look up teams going to your first regional and see if there's anyone like my team who hasn't used there line sensors and wouldn't mind giving you one. |
Are you getting any response when you deploy? If the robot does nothing, the robot is probably quitting unexpectedly, which you would receive. As for working with two photosensors, if you are dead set on using them (instead of other sensors or dead reckoning as has been suggested) I would place them directly adjacent to each other, so they can both be tripped by the tape at the same time and working with that. There may be some interference however (one receiving the reflected light from the other and returning a false positive) and it obviously won't be ideal.
Personally I find the encoders a more reliable way of making an autonomous algorithm. You simply drive until you hit a certain number of encoder counts. Then you move your manipulator. Then you drive some more. Then you place. Then you reverse.
If you're using the Iterative Robot template, the easiest way to do this is do create different state machines for the drive and each of your mechanisms. Then you create a main state machine that simply feeds these other machines values and waits for the drive or manipulator to be in place. Once the structure was created, fine tuning the numbers only took a few hours, and now we can place on any of the high pegs and the middle second level pegs reliably (as long as we're using a fresh battery that is). |
The other thing about encoders is that with some math, you can convert it to feet. You know how far back you start, so drive N feet forward and then place the piece. All the fiddling is with the arm then. |
#8
Any other teams out there willing to share how they use their encoders in autonomous? ![]() |
#9
Here's the relevant code. Code:
leftDist = bot.dt.getLeftDist() - leftStart; rightDist = bot.dt.getRightDist() - rightStart; double left = gain * ((distance - leftDist) / distance); double right = gain * ((distance - rightDist) / distance); bot.dt.drive(left, right, bot.gyro); gain is the initial value that gets toned down as you drive (Currently using 0.7) Hopefully the rest of the code is clear enough that it makes sense. If you have anymore questions feel free to ask. Also, you can PM me if you want to see our full autonomous code. |
#10
If you don't mind, can you please send me the code that has to do with your base? I'm sure I can learn from it as I can't find many resources that explain the concepts. :O |
#11
Is there any reason you can't overshoot? Fast speed to wall, then slowly backing up 6 inches may be better, unless it smashes your arm or something. Don't forget, you have 15 seconds, consistent even if slow is better than inconsistent and fast. Hope that helps a bit. |
