Go to Post ...isn't that part of the point? For high schoolers to do things they "could not have" by themselves? - AdamHeard [more]
Unread 22-02-2011, 16:49
sitzikbs sitzikbs is offline
FRC #3316
sitzikbs will become famous soon enough
mechnical arm question
hi,
we use 2 cim motor, a toughbox and sprockets to move our arm (single joint). its moving fast but if we let go of the joystick it falls down (it doesnt hold itself up).
what can we do (mechanicly\electronically) to solve this?
thanks
Unread 22-02-2011, 16:50
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: mechnical arm question
Counterweight past the pivot or surgical tubing/bungee cords as an assist.
(or any other method . . gas shocks, springs, whatnot)
Unread 22-02-2011, 18:04
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
or gas springs...
Unread 22-02-2011, 18:08
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
I saw the title of this thread, and before I clicked on it I thought to myself: "I bet the answer to the question is -- add surgical tubing."
Yep.
Add surgical tubing, neutrally balance the arm.
http://blog.iamjvn.com/2011/02/jvn-b...m-loading.html
-John
Unread 22-02-2011, 23:01
Nikhil Bajaj Nikhil Bajaj is offline
MATLAB Fan
Nikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond repute
Send a message via AIM to Nikhil Bajaj
How did you program it? Do you have feedback control running?
Unread 22-02-2011, 23:08
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
My worry: my team does not have a counterbalance or anything, just a closed loop. Now we never tested out the physical arm so... My worry is that the motor or speed controllers are going to burn out.
Unread 22-02-2011, 23:17
MATLAB Fan
@davidthefat
Well, if you're worried about it, I'm sure plenty of people around here would be happy to help you figure out if you need passive assistance (to borrow a phrase from JVN) or not. But we'd need information like the motors powering it, the gear ratio, the approximate center of gravity and weight, etc. before we could help with that.
Unread 22-02-2011, 23:20
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Originally Posted by Nikhil Bajaj View Post
@davidthefat
I'll have to get back to you on that. All I know so far is that it is ~62 inches long, using a window motor and the gear ratio is pretty big. Yea, no so informative. I been programming the whole time so I have no idea Now I don't trust WPI's PID loop (sorry guys) so I'll be writing my own from scratch
Unread 23-02-2011, 01:46
FRC #3316
we are using a counterwieght.
we dont have feedback control running, how would that work ? currently we control it buy pushing\pulling the joystick making the cim (through a jaguar) turn the arm up or down, but when its up and we let go it falls down again.
in what manner will surgical tubing help? picture anyone?
Unread 23-02-2011, 02:08
pfreivald's Avatar
AKA: Patrick Freivald
Neutral balancing with some kind of elastic potential energy device will help (assuming the geometry is right). Futhermore, setting your speed controller to 'brake' instead of 'coast' will help further.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 23-02-2011, 11:40
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
I'm not sure about the other languages, but with LabView the PID Control functions are developed by National Instruments, not WPI.
Unread 23-02-2011, 11:47
NullEntity's Avatar
NullEntity NullEntity is offline
AKA: Bryce
FRC #0093 (N.E.W. Apple Corps Robotics)
Team Role: Scout
NullEntity is an unknown quantity at this point
The C++ code uses WPI's libraries. From what I've seen it's good enough, but for more accuracy, you should create your own PID loop.
FRC Team 93 Alumni
Unread 23-02-2011, 13:10
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
I'd like to contribute here with a few pictures and details to give an example of what I feel is a very well executed arm. (I really don't mean to be bragging, I just know it works really well.)
Let me start with:
KOP FP motor and transmission and an additional 4.125 chain reduction for a total reduction of ~495:1. With the efficiency of the stages added in we have a useful power reduction of 495*.59 = 292.5:1. (BTW, the floating chain tensioner has been replaced with a fixed one, as seen in the second picture.)
The surgical tubing was added to assist the motor. It balances the arm, when the arm is retracted, at about 120 deg. When the arm is extended, it balances at about 60 deg.
This arm can easily swing 270 degrees in 4 seconds. The thing to understand is this speed is with use limiting the drive to the FP motor to only +/-35%. We are using a PID control for both positioning and to holding the arm. Honestly, even if we remove power, the arm holds it's position.
The best part is, this motor barely, if ever, rises above room temperature.
