Go to Post Robots aside, how we handle these situations, communicate with one another, resolve differences and potential conflict, and overcome obstacles defines us all as people. Remember the big picture and have fun. - Rich Kressly [more]
Unread 24-02-2011, 13:56
Team 1574's Avatar
Team 1574 Team 1574 is offline
FRC #1574
Team 1574 is an unknown quantity at this point
Minibot Motor Issues
In http://www.youtube.com/watch?v=8lRtC8wBUa0 video, the Tetrix motors are connected directly to a ~1cm axle. According to our calculations at the 154 rpm that the motors output, the minibot should move at about 6 cm/sec. The only way we can think of to make the minibot climb that fast is by removing the gear. Is this Legal?
In addition, we recently found out that there are two different types of Tetrix motors, 739083 and 739023. What is the difference between these two types of motors.
Unread 02-03-2011, 05:28
deneeshbarosa deneeshbarosa is offline
Junior Member
deneeshbarosa is an unknown quantity at this point
Re: Minibot Motor Issues
We have a Tetrix 12 volt gear motor product ID W739083. that they got in our minibot KOP & the positive connector that gives power to the motor came out of its slot. they still have the metal piece.
Unread 02-03-2011, 07:39
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Minibot Motor Issues
I don't have both motors to compare, but I would expect them to have the same power specs. Likely they have different frame mounts to the transmission plate. That plate has slotted holes to allow for different bolt spacings.
You can repair Tetrix motors per a team update with matching components. Transmissions can be modified, and adapters made to replace gears on the motor output shaft.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
