Go to Post It's sooo stressful! I brought my suitcase to school today, and I still don't know if we're going! - elfenari [more]
Unread 02-03-2011, 01:34
Carter12s's Avatar
Carter12s Carter12s is offline
FRC #2036 (Black Knights)
Carter12s is just really niceCarter12s is just really niceCarter12s is just really niceCarter12s is just really nice
Design Process, What we did v. What you did?
So this year the RoboBroncs tried to be really methodical about designing our robot. Last we built a good robot only to find that capabilities we had given it were not those that a robot really needed to be successful. This year we decided to record all the decisions we made and why we made them, and here are the results:
http://www.chiefdelphi.com/media/papers/2457
Just as a note I did not include our end effector investigation or our motor/gearbox selection, because both were a little skimpy without the physical prototypes and testing recored.
I wondered how our system compared to that used by more experienced teams, I don't know how a typical design process would work and based this off of my experience with the Project Lead The Way program at my high school. Does anyone else have records of their design process??
In case you wanted to see, this is the robot that this design process created:
http://www.youtube.com/watch?v=sturFfjv_bU
Programing is the real way to build a robot.
Unread 02-03-2011, 12:36
45Auto's Avatar
45Auto 45Auto is offline
FRC #2992
45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future
Re: Design Process, What we did v. What you did?
Your design process is fine. I would have included 6 and 8 wheel skid steer in your drive selection options, but other than that everything looks good. The secret is in applying the correct weighting factors to each of your categories. We'll know that your's were correct if we see you on Einstein!
2007 - Rookie All Star - Bayou Regional (1858 - Tyborgs)
2009 - Rookie All Star - Bayou Regional (2992 -Prometheus)
2010 - Champions - Bayou Regional (2992 -Prometheus)
2012 - Finalist - Bayou Regional (2992 - Prometheus)
team2992.com/design.php
Unread 02-03-2011, 13:14
nitneylion452's Avatar
AKA: Joe Lee
Nice bot! And I like your design process, as well.
Semi-Off Topic:
I couldn't help but notice all of the duct tape on your game piece. Were those holes from your robot or from romping, playing, and cavorting about with them?
Unread 02-03-2011, 13:43
Carter12s's Avatar
Ha, actually most of them were inflicted by the human player throwing them into the emergency sprinkler heads in the ceiling. We had at least 3 holes from that.
Unread 02-03-2011, 14:15
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
SWEET robot.
All the presentations were looking good, but I got to the drivetrain one, and I started thinking about what it looks like you guys do.
It appears that you were indentifying what you could do (ie mechanisms) before you knew what you wanted to do. We do the complete opposite here.
I also have a few questions about how you describe a few of the drivetrains. (note: I am not trying to criticise, I'm trying to learn.)
What makes mecanum "very stable at high speeds"? Ussualy, mecanum wheels are not round, seems like that would make them unstable to me.
As per the final tables at the end of your presentation, I'm curious what you might have been thinking.
What makes a swerve slow? I realize you talk about more internal friction, but many times, a swerve is done with fewer gear stages than a comparable 6wd or mecanum.
I'm really loving the use of more complex design matrixes (matrice?) and the "look back" or judgement based on the matrix, but not the final descision based on the outcome of the matrix.
A solid design process = a solid robot. Looking good for years to come and 2011 .
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 02-03-2011, 20:18
Carter12s's Avatar
Smile Re: Design Process, What we did v. What you did?
1. The Mecanum wheels were considered more stable at high speed, because when they sustain and impact from a wall or other player the wheel tend to drift. Skid drive and higher friction/torque drive trains tend not to slip and instead create higher lateral load which make a robot more likely to tip, or sustain damage.
2. Swerve drive I will be honest, is something I am very unfamiliar with. I have never built a swerve system or had the chance to see one up close. I believe my thinking on this was that the swerve would require more of the drive motors to be used for steering, and would then have less available wattage, and that the linkages to transfer the swerve power had difficulties with seizing and clogging. This was based primarily on observation of the Haywire Robotics 2010 robot which was noticeably slower than other robots, when it used swerve drive.
The reason we find all possible solutions first is because it doesn't matter how objectively you can observe an idea, unless you can come up with the right idea in the first place. For instance take the arm made by team 842:
http://www.chiefdelphi.com/forums/sh...ad.php?t=93079
The basic concept for their arm using the stationary gear linkage, was never considered for our team before hand, because we never thought to use something like that on a FIRST robot. Unless you can see all of the options, how do you know you are picking the right one?
I hope this helps and clarifies people's readings, I really more wanted to see how other teams handled the design process, since there does not seem to be a lot of material out there.
Thanks a bunch for the support!
