pic: Team 675 2011 Robot CAD
Re: pic: Team 675 2011 Robot CAD
How do you mount bumpers to this?
The bumpers have C-channel on the bottom so we just slide them on and slip in a pin.
I think the question was more directed at the large gap in the front of the frame, in terms of complying with <R07> K: "No section of the BUMPER greater than 8" may be unsupported".
It appears that the cutout in the front of the robot is wider than 8", so that section cannot legally meet all the bumper rules. You will need to put a frame member to support a bumper there. Per rule <R07> A, you need bumper coverage around your entire FRAME PERIMETER, which does include that gap. |
I believe the C channel would count as the support
#7
The frame perimeter is when you wrap a string around the robot and whatever the string touches is now defined as area for needed bumper coverage. Thus if we have a gap that is not touched by the string, we don't need to cover that area with bumpers. Thus, looking at all rules from 2008-2009, the bumper definitions are exactly the same, we would argue that having this open area in the bumpers is in fact legal. In previous year's robot we have indeed had these gaps in the frame and it was legal to not cover that area with bumpers. 2010 was the same way, except the bumper zone was higher than most people's kickers, thus most teams had bumpers around their whole robot, however there were a few that did not and it was still legal.
#8
The whole "wrap a string around the robot" thing is IMHO a poorly worded way of FIRST trying to communicate that the frame perimeter that the bumpers mount to must be a convex polygon. |
#10
For the record, The last year where full bumper coverage was not required was 2009. That arm looks like it might need to be rebuilt or at least tweaked to be able to function with a front bumper in place. You (OP) might want to pack some parts for that too. |
#11
We've built it in mind with having to place bumpers on the front of the robot, we were just curios as if we needed to or not. The arm does work with the bumpers there, but thanks for the heads up!
#12
If the C-Channel is attached to the bumpers, it would not count as support, backing, or coverage. There has to be actual robot frame to connect to on the front of your robot.
#13
We're aware, but a removable bracket bolted to the robot frame that the bumpers pin to does not count as part of the bumpers, thus it will count.
