Double Tube Autonomous
Alright Chief Delphi community, this is something that I think needs to be talked about.
We've all seen a hand full of teams include a unique ability into their autonomous: The ability to hang two tubes in autonomous. I first heard of this phenomenon after hearing of the RoboWranglers inplementation of this. I then was able to witness it live during the Pittsburgh regional, from 1114. I want to know your thoughts on this. How did they do it? What makes it work so precisely? Obviously, the act of hanging those two uber tubes is one that requires both serious speed and precision of control. Did they use a camera? Did they follow lines? What do you think? |
Re: Double Tube Autonomous
You need a roller claw, patience, and practice. If you have those three things, you've got it.
From the looks of it, I am not impressed by the programming, but I am impressed for being able to do the feat. I heard 33 used a potentiometer to track the angle of the robot.
What I think is also an interesting question is how accurate the teams are. First tube and second tube accuracy. I know 40 had a good 1 tube cap, but when they went for 2 sometimes they missed both. |
This may have been because they needed to speed up their first cap in order to have time to complete a second one.
They really didn't miss their first cap all that often. I think the match you reference is one where they just got unlucky.
As a side note, I'm glad with the completion of autonomous mode 40 got to show the virtues of a "single scorer" alliance. |
#7
We did the same type of thing in Java this year by creating an Interface for AutoModeCommands and making each one of our subtasks as a class that implements the interface. We could then just make a queue of tasks and execute them one by one. Easy. If you want to see more I can send you some code snippets. You may not be impressed for the same reason you think a potentiometer can keep track of robot heading. |
#8
PHP Code:
PHP Code:
PHP Code:
#9
I assumed it was for the motors to make a giant servo.
#10
For some reason I was under the impression that you could only start with one ubertube? Or did they grab a tube from their teammates...
#11
<G06> Each ROBOT must be in contact with one UBERTUBE. No more than one ROBOT may be contacting an UBERTUBE. Check out some double cap videos to see how some teams do it. |
