Go to Post Change 'car' to 'robot', 'coffee' to 'mountain dew' and Tom Brady to will.I.am, and you have next year's kickoff intro. - Tetraman [more]
Unread 23-03-2011, 09:35
Kett Captains's Avatar
Kett Captains Kett Captains is offline
Tired and Hungry
FRC #3098 (The Captains)
Kett Captains is an unknown quantity at this point
Exclamation Problem in Windriver Installation
I have just recently installed Windriver onto a computer that I will have with me more often. However, when trying to use the "Setup Target Connection" process to setup a link to the robot, two VERY important inputs are completely missing from the menu (The input robot address bar and the vxworks file input). I am installing on Windows 7 and our other laptop with Windows 7 was able to install and everything was there. I have deleted all of the old Windriver files also.
Does anyone know why the two boxes are missing?
P.S Ran the Workbench update also and still nothing :/
Unread 23-03-2011, 12:31
Fletch1373's Avatar
Fletch1373 Fletch1373 is offline
AKA: Fletch
FRC #3181 (Panthers)
Fletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud of
Re: Problem in Windriver Installation
If I remember correctly, this was an issue last year because Windriver does not fully support running on Windows 7. I'm not sure about this year because FIRST made us image the Classmate's with Windows 7 and some teams don't have a separate programming laptop. I can't remember if there was a fix for it, but the symptoms seem to match last year's issue.
I'll keep an eye out in the forum for possible solutions
Student:
<04: FRC0213> <05-08: FRC1373>
Mentor:
<09-10: FRC0809> <11-12: FRC3555> <12-14: FRC0073> <15-??: FRC3181>
Volunteer:
<FTAA> <CSA> <Defense Coordinator> <Scorekeeper> <Robot Inspector> <Official Scorer>
2016 Tour:
CTWAT [DefCoord] > Pittsburgh[Mentor/DefCoord] > TVR[FTAA] > FLR[CSA] > NE DCMP[CSA] > CMP[CSA]
Unread 23-03-2011, 15:41
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Wind River has known issues with Windows 7 64-bit that some UI elements do not show up. If you have 32-bit Windows 7, like what's on the Classmate PC, you are fine. Interestingly, I have a Windows 7 64-bit laptop and I have the missing UI problem. But one of my students also has Windows 7 64-bit and he doesn't have problem with his. So there must be something in addition to Windows 7 64-bit that triggers the Wind River bug. But nobody seems to know what it is.
Unread 23-03-2011, 17:43
davidalln's Avatar
davidalln davidalln is offline
World's Worst Coder
AKA: David Allen
FRC #2415 (The Westminster Wiredcats)
davidalln is on a distinguished road
Send a message via AIM to davidalln
If you can't/don't want to find another computer to use, the Universal C++ Project will let you deploy code through cygwin.
SANTOSH ANDREW DECKER RICK WYNNIE SEAN DEREK MATT
(alamo (semis), p'tree (CHAMPS!), nc (CHAMPS!), newton (quarters))
Best four years of my life. Thanks to everyone who made it happen.
Unread 24-03-2011, 09:12
Tired and Hungry
Thanks, glad to see that I'm not the only one having missing UI problems. Just wondering is there any way to solve this problem without having to run a different program? Like having 32-Bit Windows 7 or installing XP?
Unread 24-03-2011, 11:59
mikets's Avatar
Software Engineer
There were discussions about running a 32-bit OS in a VM running on top of the 64-bit Windows 7. I had installed WinXP in a VM on 64-bit Windows 7. It worked with respect to the missing UI issue, but I had issues on making the virtual network of the VM to pass through to the physical network. So I was not able to deploy and debug code in the VM. Since our team decided to buy a new team laptop anyway, I did not pursue further on the VM solution. But I am sure if I spend enough time, I would be able to configure the virtual network to make it work. I am hoping this issue will be fixed in the next season because almost all laptops come with 64-bit OS these days. Even underpowered netbooks will be 64-bit by next year.
Unread 24-03-2011, 13:16
Fletch1373's Avatar
AKA: Fletch
I know this isn't an ideal solution, but you could always install 32-bit windows on the computer. Granted, you'd have to find a copy first(easier for some than others).
just my $0.02
Student:
Mentor:
Volunteer:
2016 Tour:
Unread 24-03-2011, 13:47
mikets's Avatar
Software Engineer
That's why we bought a new team laptop. It is hard to ask any of our students to reinstall their laptop with 32-bit Windows 7. Even with a new laptop, it came with 64-bit Windows 7. We had to wipe it out and resintall the 32-bit version of Windows 7.
Unread 15-09-2011, 11:28
AKA: Brad
#0190 ( Gompei and the Herd)
I've been trying to reproduce the problem with the Workbench install not working properly on a Windows 7 64-bit system that has SP1 installed. So far it seems to be working.
Can anyone who was having the issue previously verify whether the SP1 install fixes the problem? I know it was somewhat intermittent and so it's hard to know for sure if the SP1 update (or some other update) fixed it. Or maybe I'm just not seeing it in my current Windows installation.
Thanks for the help.
Brad Miller
WPI
Brad Miller
Robotics Resource Center
Unread 15-09-2011, 12:58
mikets's Avatar
Software Engineer
FWIW, I installed WorkBench to my 64-bit laptop last year and had UI problems especially when trying to create a new project. The new project dialog UI was blank. So we bought a team laptop and installed 32-bit Windows 7 on it to get around the problem. Last week, in preparation of the new season, I started workbench on my 64-bit laptop and created a new project without even thinking. Now that you reminded me, I now wonder why I can do that now?! So it confirmed that the problem is intermittent.
Unread 15-09-2011, 15:45
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Is this something you can take a screenshot of and post here?
Thanks,
-Joe
