Go to Post I also like how the FTC folks are able to get involved with the FRC process this year, but it's always a bit of a let down when you're told you can't launch things into the air. - s_forbes [more]
Unread 23-03-2011, 17:16
mpreston mpreston is offline
FRC #3585
mpreston is an unknown quantity at this point
nxt minibot
HI I am from team 3585. I was wondering how teams connected and programmed the nxt controler to work the minibot.
Unread 23-03-2011, 18:20
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Re: nxt minibot
Just a head's up lots of team's arn't using the NXT on there mini-bot, for various reasons. You can wire directly from motor to battery (thats what we did along with other teams).
Heres a few quick tutorial that will answer all of your questions http://www.education.rec.ri.cmu.edu/...x_testbed.html
Unread 23-03-2011, 18:35
Tommy F.'s Avatar
Tommy F. Tommy F. is offline
Yeah! Collages!
AKA: 7h0m45
FRC #1985 (Robohawks)
Tommy F. is just really niceTommy F. is just really niceTommy F. is just really niceTommy F. is just really nice
Re: nxt minibot
We also didn't use an NXT. But, from my experience with FTC this year, you need a motor controller connected to the NXT, and have your motors hooked up to the motor controller. Then you need the FTC version of LabView to program the NXT.
FTC 289, 290 & 291 :: FRC 1985
2013 St. Louis Regional Semi-Finalist (with 3411 and 4330), Industrial Design Award
2013 Queen City Regional Winner (with 379 and 447)
Unread 23-03-2011, 19:16
Electrical Engineer
Rookie Year: 1995
Re: nxt minibot
Do not confuse FTC with FRC. The programs each have their own rules...
Mike Betts
As easy as 355/113...
Unread 23-03-2011, 20:30
davidalln's Avatar
davidalln davidalln is offline
World's Worst Coder
AKA: David Allen
FRC #2415 (The Westminster Wiredcats)
davidalln is on a distinguished road
Send a message via AIM to davidalln
Re: nxt minibot
Let me repeat what people are trying to say nicely: The fastest minibots this year do not use NXT. There are more efficient ways of solving the problem.
That said, MattC9's video/slideshow is an excellent start if that's the route you want to take.
SANTOSH ANDREW DECKER RICK WYNNIE SEAN DEREK MATT
(alamo (semis), p'tree (CHAMPS!), nc (CHAMPS!), newton (quarters))
Best four years of my life. Thanks to everyone who made it happen.
Unread 23-03-2011, 20:36
AcesJames's Avatar
AcesJames AcesJames is offline
Mentor, still learning
AKA: James Temple
FRC #2170 (Titanium Tomahawks)(EWCP)
AcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond repute
Send a message via AIM to AcesJames Send a message via MSN to AcesJames
Re: nxt minibot
176's first minibot has an NXT brick on it. It was used because the person making the minibot did not know how to wire limit switches and household switches to change the polarity and/or stop the current to the motors as he desired. That minibot weighs 7 pounds now, and climbs in 9 seconds.
I would advise against using the NXT. You don't need it. If you've created a minibot that is so complicated it needs an NXT brick, you've done it wrong.
Our second minibot is 2 motors, with direct drive to the FTC wheels, and a batter strapped to the back with a few switches to control the polarity and on/off. This minibot weighs about 3 pounds and climbs in roughly 3 seconds. It's not a super fast minibot, but it took less time to make than the far more complicated NXT bot, and is much faster.
FRC 176 - Aces High - 09-12 - Student
FRC 229 - Division By Zero - 13-14 - "Mentor"
FRC 2170 - Titanium Tomahawks - 17-Now - Mentor
Unread 23-03-2011, 21:48
chemipanda chemipanda is offline
Budha
FRC #0240 (TEMPEST)
chemipanda is an unknown quantity at this point
Re: nxt minibot
Where may I find that video/slidshow at?
Unread 23-03-2011, 21:56
nitneylion452's Avatar
AKA: Joe Lee
Re: nxt minibot
MattC9 posted it above
Unread 23-03-2011, 18:33
Jin Hayashi's Avatar
Jin Hayashi Jin Hayashi is offline
FRC #2930 (Glacier Peak Robotics - The Sonic Squirrels)
Jin Hayashi will become famous soon enough
Re: nxt minibot
Our team team was probably one of the few teams to use the NXT module with the minibot. It was probably the slowest minibot on the field, but only about 8-10 teams were able to successfully deploy a minibot at our regional.
Maybe half of those teams were able to reliably launch a minibot.
We used the documents and videos downloaded from
http://www.tetrixrobotics.org/MINDST...lt.aspx?aid=42 for ideas on how to create our minibot with the NXT brick.
We programmed with the software package that comes with the NXT Mindstorms.
Videos of our minibot can be found at http://www.youtube.com/watch?v=DboK1..._order&list=UL and
http://www.youtube.com/watch?v=W26bP...x=1&playnext=7
