VxWorks6x
ah well, we've been using another laptop for programmming so far and now a mentor has it with him while I have somthing that is notorious for not working.
Windriver works. however, i can't connect with the target console. I went though the default for making the vxworks target console, and it won't work. ip addresses for laptop = 10.24.5.9, 10.24.5.5 = crio in case any want to know by tether. anything, anyone? |
Re: VxWorks6x
IIRC, the cRIO ip address should be 10.24.5.2 and the laptop should be 10.24.5.6
Re: VxWorks6x
That might help. I'll check it tomarrow.
Anyone else have any other ideas, more than welcome. EDIT: IP change helped, but didn't fix it. I have some pics of errors now. In the meantime, my eternal gratitude to 2474 and their programmer who reconfigged his laptop just for us so that we could send new code to our bot. ![]() Last edited by kws4000 : 03-25-2011 at 10:36 PM. |
Re: VxWorks6x
The next step in debugging is to make sure that you can see the cRIO via the network. Open a CMD box on your XP and issue a "ping 10.24.5.2" to see if you get a response. If not, then you do not have connectivity established. Use "ipconfig" from the CMD box to verify that the IP address is set to what you think it is. Anything on the 10.24.5.x net (except 10.24.5.2) should be fair game. Also verify that your subnet is set to 10.0.0.0. Finally, make sure that you're not running some sort of firewall software like Norton or Mcafee as these will block the ports you're trying to get to. HTH, Mike |
Re: VxWorks6x
XP, running on Intel Centrino Duo inside a Lenovo. Not sure about Bit-size though.
no security software at all, it doesn't connect to internet because we don't use it for that ping works, as does reimaging and i'm pretty sure the subnet should be 255.0.0.0 |
Re: VxWorks6x
Good Luck, Mike |
#7
Re: VxWorks6x
seeing as how the season is over, i'll try it whenever I get the chance.
Thanks, yall. |
