Go to Post In engineering, it's important to use the appropriate tools and not more resources than are required. - AdamHeard [more]
Unread 10-04-2011, 19:14
William3370 William3370 is offline
Programming & Electronics Captain
FRC #3370 (Aftershock)
William3370 is an unknown quantity at this point
I/O
I know this falls a bit under the electronics category but next year it appears very likely that I will be both the lead programmer and the lead electronics captain. While I'm fairly knowledgeable in both, I have no idea what the I/O is for or what it can do (programming wise). Can anyone tell me?
Unread 10-04-2011, 19:27
Re: I/O
I is for Input. It's how the robot program can sense things.
O is for Output. It's how the robot program can move things.
Can you be a little more specific about what you're asking?
Unread 10-04-2011, 19:48
Re: I/O
Sorry if I was unclear, but as I said i'm confused to.
Let's see...
The I/O tab is only used if you have the Cypress board attached. The Cypress is the best/easiest way to use non-joysticks to control the robot.
Found that in another thread and so I was wondering of the potential possibilities such as can I use it for wiring a ps3 or xbox controller? Can I make a custom joystick and button pad (saw a few teams do that this year)?
And if so how would I go about programming it?
William
Team 3370
Lead Programming Captain
Lead Electronics Captain
Unread 10-04-2011, 22:31
Re: I/O
In its normal mode, the Cypress board can read the state of a bunch of switches and a handful of knobs, and control a few LEDs. In "enhanced" mode, it can also read encoders, touch sensors, and built-in accelerometers, and generate voltages and PWM signals. It is indeed a good way to implement a "button box" in addition to the USB joysticks or game controllers.
You don't actually program the board itself. The Driver Station application reads it for you and passes the information on to the robot, where the program on the cRIO can read the values of the switches and knobs connected to the board. You will find the functions for reading it in either the Compatibility IO or Enhanced IO subpalettes (they're in the DriverStation section of the WPI Robotics Library functions).
Unread 10-04-2011, 23:30
mesamb1's Avatar
mesamb1 mesamb1 is offline
AKA: Sam Bacon
FRC #1466 (Webb Robotics)
mesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nice
Re: I/O
Alan Anderson is dead right
But am I wrong in understanding you want to use the cypress board to hook up the ps3 and xbox controller?
because both of those you can plug straight into your driver station and as long as you have the drivers for them will be recognized as essentially a box of buttons and knobs.(You can order in the driver station which USB ports they are associated with, to match how they are called in the CRIO)
Cypress board is very helpful, but particularly if your trying to make a custom arrangement to ease the difficulty of driving your bot.
