Go to Post Q: "What does your robot do?" A: "It collects data about the surrounding environment, then discards it and drives into walls" - tsaksa [more]
Go Back   Chief Delphi > Competition > Championship Event
Unread 12-04-2011, 14:25
mrRefresh74's Avatar
mrRefresh74 mrRefresh74 is offline
FRC #0074 (Holland C.H.A.O.S.)
mrRefresh74 is an unknown quantity at this point
WIFI at St. Louis?
Does anyone know if there will be wifi that I can connect to for my iPod app FRC Tracker 2011? If not, I will need to check into getting access through my cell phone.
Unread 12-04-2011, 14:57
kenavt's Avatar
kenavt kenavt is offline
AKA: Colin S
kenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond repute
Re: WIFI at St. Louis?
A couple of my friends on my team and others were posing this question just yesterday. This was the appropriate web site I found:
http://www.explorestlouis.com/media/...s/wireless.asp
Apparently, the system has support for 4000 users. That means it will likely be pushed to its limits. However, it's at least a good thing that it will be present.
University of Michigan Computer Engineering '17
FRC 2337 student alumni (2010-2013)
Unread 12-04-2011, 16:34
"Because America's Center is designed to accommodate multiple, simultaneous events, the wireless system also can be custom set with different security levels for specific access points and client needs. This means that free access or password-secured access can be set for select areas in the facility."
FIRST might require the Wi-Fi network to be shut down, or at least drastically limited in its availability. That was done in at least one regional venue in order to eliminate interference with the field network.
Unread 12-04-2011, 18:33
David Dawson's Avatar
David Dawson David Dawson is offline
Capt'n turned Mentor
FRC #3771 (Yooper Troopers)
David Dawson will become famous soon enoughDavid Dawson will become famous soon enough
I never understood this. I was told the field runs on 5ghz which isn't bothered by 2.4.
Unread 12-04-2011, 20:55
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
Alan, you are correct.. In week 1 FLR was devastated on practice day because of RIT's wireless network. In Boston, the wireless was shut completely off.
I would expect the same thing to happen in St. Louis.
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 12-04-2011, 22:14
agamemnon agamemnon is offline
FRC #0088
agamemnon is an unknown quantity at this point
In Boston I remember they were going to set up free wireless, which got cancelled, but there were still at least 3 BU networks up. I was connected to the BU Guest network, on the internet.
Unread 13-04-2011, 10:13
Racer26 Racer26 is offline
Far as I understand, RIT has a jamming signal to kill off unauthorized networks and such, and so, it saw the field network as a foreign signal and was killing it at FLR.
Unread 13-04-2011, 12:02
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
I'll clear this up since I was involved in the issue at FLR, and in subsequently making sure it wouldn't be a problem at Waterloo and GTR.
The problem is with the new Wi-Fi bridges on the robots. In "bridge" mode, there is no way to force them to look only for 5GHz networks as there was with the previous years' models. When initially trying to link up to the 5GHz network from the field corresponding to the robot's team number, their mode of operation is to first scan through all the 2.4GHz networks present looking for a match before trying the 5GHz networks.
To compound this, there is some kind of issue where if there are more than a certain number of access points present (not just networks, as multiple AP's can be broadcasting the same SSID), it fills up some internal buffer, and the bridge can't see any networks past that. This results in the bridge never finding the correct 5GHz network to connect to.
The number I've heard that starts happening at is 30, so if more than 30 AP's are present in a venue, whether they're 2.4GHz or 5GHz, the only solution is to shut some of them down.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 19-04-2011, 09:54
According to the Championship A-Z document (updated 4/15):
Free wireless internet access is now available in the common areas of the America’s
Center. This access is not available on the pit floor. Due to the wireless nature of
FIRST control systems, wireless availability will be evaluated during the course of the
event. Teams will not be allowed to set up their own wireless networks at the
Championship. While we certainly appreciate the positive potential team-created
wireless networks could represent, there is a chance such wireless networks could
interfere with planned activities during the event.
