Go to Post Because when you build the people and the team, building the robot comes much easier. - Koko Ed [more]
Go Back   Chief Delphi > Competition > Championship Event
Unread 15-04-2011, 18:13
2011 Curie Division
Discussion for Curie
Unread 15-04-2011, 18:23
cziggy343's Avatar
cziggy343 cziggy343 is offline
cziggy343
AKA: Chris Z
FRC #0343 (Metal-in-Motion)
cziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond repute
Send a message via AIM to cziggy343
Re: 2011 Curie Division
Anyone really smart that has the data to do OPR ranks wanna do them for Curie?
Diamond Bullet Studios Co-Founder
http://www.dbsgames.net/index.php
Unread 15-04-2011, 18:28
Josh Drake's Avatar
Josh Drake Josh Drake is offline
Engineering Mentor
FRC #5403 (Aluminosity)
Josh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond repute
Time to break that darn curse!!
07'-10' FRC 343
11'-12' FRC 2751
13'-14' FRC 3494
15'-16' FRC 5403
Unread 15-04-2011, 18:45
The Lucas's Avatar
CaMOElot, it is a silly place
OPR Ranks Using Highest Event OPR
2056	67.4726	ON2
71	66.3664	TN
67	64.1978	MI
987	62.3787	NV
2363	57.9409	SC
1986	57.5391	CO
1678	55.5372	SAC
1717	53.4482	CA
968	52.7023	CA
1983	49.2999	OR
180	49.1931	SC
2751	48.4114	NC
1923	48.2937	CT
768	47.8643	DC
599	46.6751	CA
1625	45.6884	IL
365	45.5536	PA
1559	44.6337	OH
573	43.6522	OC1
103	42.8265	PA
51	42.6856	DT
245	41.5763	GL
1519	40.1307	NH
368	39.8456	HI
135	37.2743	IL
364	37.1508	LA
2081	36.512	IN
1507	35.8615	PIT
2471	33.7167	OR
176	33.3603	CT
1024	33.1398	TN
2996	31.7413	CO
316	31.612	PA
1574	28.9023	IS
2826	27.8519	WI
1927	26.8485	LA
141	26.4447	MN
57	26.1058	TX
2702	25.3833	WAT
1741	24.7754	TN
2990	23.6406	OR
126	23.3955	CT
1675	22.9333	WI
687	21.5913	CA
1626	21.38	LI
1241	21.2009	ON
3507	20.696	DA
2177	20.6041	MN2
3130	19.366	MN2
2102	19.1677	SD
166	19.0343	NV
60	17.7511	AZ
20	17.4105	CT
3630	17.4023	MN
122	16.927	VA
2377	16.3261	MD
3784	16.0011	KC
3799	15.0128	ROC
3459	11.3486	NC
3473	10.2649	CA
1891	10.1374	UT
375	10.0862	NY
335	8.31019	NY
2359	7.29043	OK
3477	7.1048	SD
3739	7.09076	ON2
2761	6.66516	SAC
2283	4.90852	DA
1739	4.27756	IL
2783	4.26227	IN
3766	4.20465	IS
3172	4.0502	KC
2040	3.93707	IN
3158	3.03322	AZ
246	2.63356	MA
401	1.58952	VA
2556	1.32049	FL
3160	0.213624	OK
3037	-0.794259	DA
3651	-0.887429	SC
3553	-1.02732	PA
2486	-1.52368	AZ
3239	-1.7798	UT
1836	-1.86209	CA
3624	-4.23656	LI
3492	-5.06835	PIT
3685	-6.81972	HI
120	-10.3589	OH
Here it is using Travis's Avg OPR data from his Fake Divisions Sheet
Team	Avg OPR	Num Events
987	58.78895	2
2056	57.29226667	3
1678	55.5372	1
2363	53.9905	2
71	49.78725	2
1986	44.8024	2
1717	43.04975	2
67	41.54633333	3
1983	41.35155	2
573	39.97643333	3
368	39.8456	1
365	39.73325	2
1923	38.3613	2
1625	37.6844	2
364	37.1508	1
2751	36.9249	2
180	36.80135	2
2081	36.512	1
1507	35.8615	1
768	35.78415	2
51	34.82135	4
599	33.47605	2
1519	33.02965	2
1559	32.33575	2
103	32.0282	2
2471	31.77895	2
245	29.0901	5
1574	28.9023	1
968	28.572965	2
176	28.429	2
2826	27.5076	2
1024	26.9526	2
1927	26.8485	1
135	25.01805	2
1675	21.6672	2
316	20.253595	2
126	19.94215	2
2177	19.8408	2
1626	19.57585	2
3130	19.366	1
2996	19.32461	2
2702	19.30065	2
3630	17.4023	1
2990	17.35935	2
2102	16.38075	2
20	16.15055	2
3784	16.0011	1
122	15.81135	2
687	15.56901	2
1241	15.56266667	3
3799	15.0128	1
141	14.969778	5
57	14.443645	2
2377	13.8176	2
166	12.253385	2
1741	11.77173	2
3459	11.3486	1
3473	10.2649	1
1891	10.1374	1
3507	10.090474	2
60	8.8893	2
335	8.31019	1
2359	7.29043	1
3477	7.1048	1
3739	7.09076	1
2761	6.66516	1
375	6.61259	2
2283	4.90852	1
3158	4.63962	1
2783	4.26227	1
3766	4.20465	1
3172	4.0502	1
2040	3.93707	1
246	2.63356	1
2486	2.38916	1
401	1.58952	1
2556	1.32049	1
1739	0.22588	2
3160	0.213624	1
3037	-0.794259	1
3651	-0.887429	1
3553	-1.02732	1
3239	-1.7798	1
1836	-1.86209	1
3624	-4.23656	1
3492	-5.06835	1
3685	-6.81972	1
120	-10.3589	1
I can't get the latest World Rank Data from Ed Law's database since it will not convert to pre-07 Excel format. Anyone have that data?
Robot Inspector
Unread 15-04-2011, 18:49
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
The_Lucas, thanks man - do you think you could do the same for Newton?
I know i cannot wait to work with the some of the best teams in FIRST.
Lets have some fun!
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 15-04-2011, 19:27
Blackphantom91's Avatar
Blackphantom91 Blackphantom91 is offline
Mentor + 4 = Stuck For Life
AKA: Malcolm Stirckland
FRC #1986 (Team Titanium)
Blackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura about
Yes curie again lets do this and make this a great division, Good luck to all.
[img*]http://i.imgur.com/Os2oTET.jpg[/img*]
Unread 15-04-2011, 19:34
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
no team (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
This division looks pretty interesting. Some great teams, and some huge competition! Should be a great Championship, and division!
Unread 15-04-2011, 19:42
Team 1574's Avatar
Team 1574 Team 1574 is offline
FRC #1574
Team 1574 is an unknown quantity at this point
What a great division!!!
see you there
MisCar 1574
2005 Triple Play : Israel Regional Winners |2006 Rack N Roll : Israel Regional Winners
2007 OverDrive : Israel Regional Winners | 2008 Aim High : Israel Regional Winners, Newton Finalist
2011 Logo Motion : Israel Regional Winners | 2012 Rebound Rumble :Engineering Inspiration Award, Regional Finalist |
2013 Ultimate Ascent: Regional Finalist, Excellence in Engineering Award |
2014 Ariel Assist : Israel Regional Winners |2015 Recycle Rush : Israel Regional Winners, Engineering Inspiration Award
Our 2015 Robot : https://www.youtube.com/watch?v=Hf38BT8Q55E | Our website : www.miscar1574.org
Unread 15-04-2011, 20:03
WOO! We're not the team with the lowest OPR here lol
Can't wait for alliance selections.
Unread 15-04-2011, 20:36
Bob Steele's Avatar
On the RIBMEATS bandwagon....
AKA: Bob Steele
The Skunks are looking forward to being on the field with everyone!!
Good luck to everyone and we will see you on the field(s)
Go CURIE!!!
Unread 15-04-2011, 20:48
BIGWILLI2081's Avatar
BIGWILLI2081 BIGWILLI2081 is offline
FRC #2081 (Icarus)
BIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of light
Curie, along with all the other divisions, is looking really strong. We can't wait to compete with everyone!
2011 Boilermaker Regional Champions
2011 Boilermaker Motorola Quality Award
2011 Boilermaker Autodesk Excellence in Design Award
2010 Boilermaker Regional Finalists
2009 Boilermaker General Motors Industrial Design Award
2008 Boilermaker Engineering Inspiration Award
2007 Boilermaker Rookie All-Star Award
Unread 15-04-2011, 20:57
Gaurav27's Avatar
Gaurav27 Gaurav27 is offline
Gaurav Bhatt
FRC #1241 (THEORY 6)
Gaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of light
Awesome! Curie seems to be a strong division! Lets all make it an amazing division. Can't wait to compete with you all! Good Luck everyone!
2016 Newton SubDivision Finalists [254,1731,708]
2016 Waterloo Winners [610,3560]
2016 North Bay Winners [1310,2935]
2013 World Champions [1477,610]
2013 Galileo Division Champions [1477,610]
Unread 15-04-2011, 23:25
twetherbee twetherbee is offline
Mentor, Team 987
FRC #0987 (High Rollers)
twetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud of
Can't wait for St. Louis!! Seeing old friends and making new ones. Curie will more formidable than people think.....
This is from the Week 6 data:
Team World Rank
987 4
2056 6
2363 10
71 15
1678 27
1986 33
2081 35
1983 37
1717 41
368 44
365 49
573 51
67 55
1923 57
2471 61
364 65
599 70
2751 73
51 80
180 82
2826 83
1519 87
1625 88
768 93
1574 104
176 113
245 115
103 121
1559 124
1507 161
1927 163
968 195
1024 201
1626 217
2702 255
135 261
3630 265
126 278
316 293
1675 308
2177 312
122 323
335 348
3130 357
2990 363
2102 369
2996 392
20 406
3507 411
141 441
1241 443
2377 465
3473 466
3459 475
60 535
1741 557
375 580
3160 605
166 629
3239 640
1891 642
3477 663
2761 708
2040 729
3739 762
687 798
2359 808
3172 832
3553 1008
3784 1029
3766 1070
246 1119
2783 1165
2486 1205
57 1235
3158 1247
2283 1259
401 1282
1836 1588
2556 1613
1739 1723
3685 1772
3651 1873
3624 1927
120 1928
3037 1989
3492 2041
Unread 15-04-2011, 23:38
princessnatalie's Avatar
princessnatalie princessnatalie is offline
AKA: Natalie
FRC #2471 (Team Mean Machine)
princessnatalie has much to be proud ofprincessnatalie has much to be proud ofprincessnatalie has much to be proud ofprincessnatalie has much to be proud ofprincessnatalie has much to be proud ofprincessnatalie has much to be proud ofprincessnatalie has much to be proud ofprincessnatalie has much to be proud of
All of Team Mean Machine is also pretty excited to be on Curie!
Especially with Skunkworks and Hotwire, our PNW friends <3
Seattle Cascade Regional Champions
thanks 2046 and 492
Autodesk Oregon Regional
2011 Seattle Cascade Regional Champions
thanks 1510 & 2660
2011 Autodesk Oregon Regional Champions
thanks 360 & 3711
Unread 16-04-2011, 01:33
PaW's Avatar
PaW PaW is offline
AKA: Paul W
FRC #1899 (Saints Robotics)
PaW has a spectacular aura aboutPaW has a spectacular aura about
"World Domination !!!"
GO PNW!
Break the curse...
