pic: 2791 Drivetrain Close-Up
Re: pic: 2791 Drivetrain Close-Up
Its sooo clean!! But if you snap a belt or if you have to perform work on the intervals if the drive (belts ect.) how do you get in there?
looks sweet and clean. we do the same thing with gears (partially) inside the box tube connecting our inner 2 wheels, and chain inside the tubing connecting them to the outer 2.
Very nice!
Now, if you can only do something about all that neon green tubing..... ![]() |
There appear to be sliders on each side of the central pulley. Is it safe to assume those are to ensure the proper belt wrap?
Very Clean, this style drive is something we will be looking into this offseason. |
I am slightly confused I feel as if i must be missing something... how do you get enough traction between the belt and that pulley. It feels like there must be a detail not shown by this view.
#7
Looks like the mounting plate is for another motor. Were you planning for 2 FP motors in the kit?
#8
IIRC, the drive was designed to accommodate 2 RS775's, if 2791 saw the need for them.
#9
Cleanest drive I've seen in a while. Glad you've got your head on straight about axles now... -Nick |
#10
Always ensure proper belt wrap! It's super important. Quote:
Do you know what the gear ratio is... it looks like it was originally a CIMple box and then you have a chain changing the gear ratio again.... is this true
Thanks ![]() |
#12
It's designed to use the Toughbox gears. We probably should have used the CIMple Box gears, but we didn't think to.
I believe the chain reduction is 10:24, so the final reduction is something like 8.5:1. |
#13
The part of the belt shown is probably the wrap going back from end to end. There is probably belt wrap under the part of the belt you can see.
