Go to Post When you open of CD and you see your very own quote up top, and can't decide if it's a really awesome or "Well...this is awkward..." moment - CalTran [more]
Unread 10-05-2011, 19:08
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Perfect Drive?
After looking at swerve drive for the past 2 months. (from the end of regionals to now), For a school project it has dawned on me that, swerve is to heavy, complicated and to "hard" to make for the things you want it to do.
I was one of those people that thought swerve was the best thing since sliced bread, but like i said above its not, fun train, but it doesn't look like I have the resources and time to pull it off.
I want to build a GREAT drive train for the off season and I want it to be quick, maneuverable, light, and powerful (the ideal drive). It looks like swerve and mecanum are out for various reasons. So my quest, To create a great 6WD or 8? A tough box on am frame is GREAT!! but I want to take it a step higher.
I was experimenting today in the shop with a CIMple box and a 12t to a 22t sprocket. The overall reduction is 8.6 (Thanks JVN for the drive calculator!!!). With a robot that weighs 120lbs. it will draw about 102apms per motor. (I know not that much about electronics) is this to much current to be drawing (i would be drawing about 408amps total).
Also mechanically,
Belts, chain or Spur-gear ran wheels?
6 wheels or 8?
Sheet metal or alum. Tubing?
Live or dead axles?
If you can answer any of these questions it would be great! and if you have any other advice I would love to hear it!
Unread 10-05-2011, 19:23
Re: Perfect Drive?
How did you come up with this number?
Unread 10-05-2011, 20:40
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Perfect Drive?
JVN worked up an Excel spreadsheet drivetrain calculator years ago. It makes some basic assumptions about the physics to estimate the required torque to turn a skid-steer robot. Then it matches it to the motor curves to determine amps. It's not 100% accurate, but it's a good rule of thumb. Especially if it's telling you you're pulling 110 amps in a turn. I'll grant that that's probably an over estimate, since it doesn't account for pesky realities like the battery's internal resistance dropping your volts from 12 to 8 under a 400 amp load.
@MattC, Unless you've screwed up the settings on the wheelbase dimensions, that's a good indicator that you're geared too fast. I'm assuming you're working off 8" wheels, in which case that's something like a 20 fps robot you've got there. That's insanely fast. It's been a few years since we've done a skid steer, so I don't have a great feel for the appropriate top speed, but that seems excessive. You're going to end up with a lack of torque and the huge current draws in turns like you're seeing. I'd think about dropping the gear ratio a hair to get more torque so you're not beating your batteries quite so close to death. Also recall that a competition robot is 120 lbs dry weight. Bumpers and a battery add another 20-25 lbs, which is going to increase your current draw even more.
Unread 10-05-2011, 20:55
Billfred's Avatar
Billfred Billfred is offline
Re: Perfect Drive?
This. Most drive systems top out in the 12-14 ft/s range; a few teams will stretch it to 16 if it plays into their strategy.
Another thing to consider: Machinability with the resources available to your team. An extra week of driving practice and shakedown outweighs a lot of ooo-shiny.
Unread 10-05-2011, 21:06
Clark Pappas's Avatar
Clark Pappas Clark Pappas is offline
Team Captain
FRC #4068
Clark Pappas is an unknown quantity at this point
Re: Perfect Drive?
...in which case that's something like a 20 fps robot you've got there. That's insanely fast.
Agreed. We re-used gears on our 2010 prototype, Black Knight, to save time and money. It ended up being geared at 22 feet a second. I drove it for an off season event, and it was nearly impossible to keep reasonably good control of it in the 3 tiny zones in breakaway. Stay away from those speeds
(Wth 4068)
2012 Colorado Rookie Inspiration award
(With 973)
2011 FRC Championship Winner
2011 Galileo Division Winner
2011 Long Beach Motorola Quality Award
2011 San Diego Industrial Design Award
2010 Las Vegas Finalist
Unread 10-05-2011, 21:12
Re: Perfect Drive?
Thanks Kevin, I am aware of John's spreadsheet.
@Matt: Is that how you got 102 amps? You used JVN's spreadsheet to calculate amps for a skid-steer turn?
Unread 10-05-2011, 22:16
MattC9's Avatar
Re: Perfect Drive?
Yes, I used JVN's spreadsheet to get my numbers.
@kevin I'm running my numbers on 6in wheels. I am at 13fps, if i saw 20, i would know somethings wrong.
@Ether I did run these numbers trough his spreadsheet to get 102amps. I did use it to calculate for a skid-steer, and i'm scening it wasn't men't for this? And this is why i asked if 102 was to much, it sounded a little high to me, because the jags have a 40amp cut off.
@bill This is why I'm starting with the raw needs then building from here.
Unread 10-05-2011, 22:57
Re: Perfect Drive?
13 feet/sec vehicle speed, 8.6:1 gear ratio from CIM rpm to wheel rpm, 6" diameter wheels, 90% gear plus sprocket efficiency:
8.6		gear ratio from motor to wheel
6		inch diameter wheels
90%		power efficiency of gearbox and sprocket
18.85		vehicle inches per wheel rev
156.00		in/sec vehicle speed
8.28		wheel rev/sec
496.56		wheel rpm
4270.45		motor rpm
67.30		oz-in CIM motor torque @ 4270 motor rpm
520.90		oz-in wheel torque
173.63		oz wheel force
10.85		lbs wheel force
43.41		lbs for 4 wheels
43 pounds force just to keep the vehicle moving at 13 fps on a flat surface?
Does that sound right?
Unread 10-05-2011, 23:22
MattC9's Avatar
Re: Perfect Drive?
I'm attaching some screen shots of my numbers to this post so you can look at them 1st hand.
Unread 11-05-2011, 00:22
Re: Perfect Drive?
Looks like the 81% "Speed Loss Constant" is directly responsible for the 41 pounds of force required to sustain constant motion.
Also, the 102 amps appears to be the motor torque required to break traction, and is driven by the "Contact Coef of Friction".
John, if you are lurking, could you please shed some light on what are the physical contributors to this "Speed Loss Constant"? The only thing I can think of off-hand would be the rolling friction and the friction in the wheel bearings, since all the drivetrain friction should already be included in the "Drivetrain Efficiency" number, n'est-ce pas?
Unread 11-05-2011, 00:57
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Perfect Drive?
I can't find the post at the moment, but I believe both the default drivetrain efficiency and speed loss constant are anecdotally derived scale factors for torque and speed respectively.
Unread 11-05-2011, 02:15
Re: Perfect Drive?
Yes, but each must ultimately have a basis in physical reality.
Unread 11-05-2011, 03:53
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Perfect Drive?
On 968, over the years we experimentally determined that about 17 ft/sec is pretty much the upper limit for 4-CIMs playing most games on the standard size field. Anything over that and the acceleration just really seems to drop off (I base this on no math, but just what it felt like from a driver's perspective). In 2008 for Overdrive, we were geared up around 20 ft/sec, but it had the Fisher Price motors in there too. That thing was a real blast to go hauling around the oval track. If I recall, we were getting in the range of 8-second laps around the field. But, we had very well refined cornering code that let us carry the speed through a nice arc around the divider. When we pulled out the Fisher Price motors to use on another mechanism, it got noticeably slower. Also, we started burning out CIMs, even just in 2-minute matches.
Unread 10-05-2011, 19:43
electron's Avatar
electron electron is offline
Former Team Overdrive member
AKA: Joseph
FTC #2753 (Team Overdrive)
electron is just really niceelectron is just really niceelectron is just really niceelectron is just really nice
Re: Perfect Drive?
well, if you are going to be using the FIRST electricial components, all of you CIM motors will be on 40 amp breakers, so the maximum current draw could be 160 amps. (somebody correct me if I'm very wrong)
My experiences with FRC drivetrains was limited to just one year, but I never saw our drive train draw more than ~35-38 amps/motor.
As for the mechanical aspect, I would not be the person to talk to
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
I may be one of the few people that has moved from FRC to FTC, and enjoyed it
Unread 10-05-2011, 20:21
Re: Perfect Drive?
According to the MX5 datasheet, it could take up to 47 seconds to trip at 150% overload (60 amps) and still be in-spec.
