Go to Post I can attest that mentoring is probably the most important aspect of this program. - Tom Bottiglieri [more]
Unread 15-05-2011, 12:28
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Solenoid for tshirt cannon, will this work
Found a solenoid at princess auto, will it's specs be high enough for a tshirt cannon?
http://www.princessauto.com/power-tr...solenoid-valve
Unread 15-05-2011, 13:23
Jim Wilks Jim Wilks is offline
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
Re: Solenoid for tshirt cannon, will this work
Specs are fine for safety. The only question is whether 1/2" is a big enough bore to get the flow for the shooting range you desire.
Unread 15-05-2011, 22:56
lemiant's Avatar
the Dreamer
AKA: Alex
Yeah, how far could 1/2" go?
Unread 15-05-2011, 23:50
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
You could find a larger manual butterfly valve (or some other kind of valve) and mate the handle/actuator to a motor or a pneumatic cylinder controlled by a smaller solenoid. Assuming you already have a solenoid and cylinder, It could end up being cheaper in the end.
Unread 15-05-2011, 23:51
lemiant's Avatar
the Dreamer
AKA: Alex
How about 200 psi and 1" inner diameter. Its cv factor 14 if that helps.
