Go to Post And when I heard the word "Mentor Round" - you had me SOLD. - Chris is me [more]
Unread 20-05-2011, 13:20
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Mirrored Super Shifter
Does Andymark sell them? I know you can just rotate one, but it would be cool if there were actually left side and right side super shifters.
Unread 20-05-2011, 14:11
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Mirrored Super Shifter
But then they would be even more expensive.
Unread 20-05-2011, 14:39
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Disclaimer: I can't look at the CAD model for the SuperShifter on this computer (I'm basing this only on photos on AM's website), so take this with a grain of salt.
If you are using the pneumatic shifting option for the SuperShifter (this won't work for the servo shifter/encoder mounting bracket), couldn't you just take apart the SuperShifter, and reassemble it mirrored simply by bolting everything to the opposite side of the two face plates?
Art Dutra IV
世上无难事,只怕有心人.
Unread 20-05-2011, 14:47
AdamHeard's Avatar
Lead Mentor
In 2008 we ran stock SSs without reassembling them, and we achieved the "mirror" by rotating one 90*. This puts a CIM up higher, so it's a bit less efficienty CG wise, but it puts the shaft in the right spot. You're talking a very marginal difference in CG (I want to say 2.5 lbs * the 2.5" inches it's moved/ 150 lb total... so like .05 inches).
Going into the 2009 season, we designed around repacking SS guts into our own setup, and we did actually internally reassemble them to be perfect mirror images.
It's possible either way, I really recommended the first option though, a lot easier.
Unread 20-05-2011, 16:05
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
In 2008, Team 48 ran stock SuperShifters. We did disassemble one and reassembled it mirrored to balance the layout. My memory may be iffy, but I believe it requires disassembly down to popping out the roller bearings from the side plates and repressing them on the opposite side...but I know it can be done.
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 20-05-2011, 16:19
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
we actually had mirrored super shifters, i think we had to make a plate on top of the re-stacking of the transmissions to make them work like what we wanted.
Unread 20-05-2011, 17:01
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
I thought this thread would be about very shiny super shifters.
I don't have a lot of experience with the SS's; is the weight difference so dramatic that you have to have them exactly symmetric?
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 24-05-2011, 16:19
DonRotolo's Avatar
Back to humble
FRC #0832
Same here, I was going to suggest self-adhesive shiny mylar instead of polishing them...
Anyway, it's less a question of center of gravity but one of having a reasonably symmetrical space for other components. This year we went nonsymmetrical and it was OK, but I can imagine other cases.
