Go to Post Quality has nothing to do with desire – you can’t wish quality. Quality has nothing to do with time, or money, or the other guy’s attitude. Quality has everything to do with craftsmanship. - Jack Jones [more]
Unread 22-05-2011, 23:31
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Copying renames Parameters
I have created a rounded triangle pattern to decrease weight, whose dimensions are controlled by user parameters (d50 = TriBase, d51 = TriHeight, etc.). However, whenever I copy the triangle, instead of the new dimensions referencing the correct user parameters (d53 = TriBase, d54 = TriHeight), it creates new unnamed user parameters for the dimensions to reference (d53 = d55, d54 = d56). How can I copy the triangle while still referencing the same user parameters?
I have posted a CAD here (http://host.codingproject.net/Side_Plate_R2.1.ipt) with the original (middle), a copy made by remaking the triangle (right), this is what I would like the copy to be, and one actually made by copying (left).
Unread 23-05-2011, 17:12
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: Copying renames Parameters
The best way to do this would be to create a triangle and fillet it. Then, after that, cut it out and pattern it down throughout the plate.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 23-05-2011, 17:17
lemiant's Avatar
the Dreamer
AKA: Alex
Thanks for the response. How do I pattern it down the plate? Will that cause it to update if I change the parameters?
Unread 23-05-2011, 18:01
slijin's Avatar
Pockets
AKA: Samuel Lijin
In the sketch, create one triangle where you want to begin to pattern it. Fillet it appropriately, finish the sketch, then cut out the triangle. In the ribbon, select the Rectangular option under Patterns. Select the cut-out triangle, then switch to selecting direction for the pattern. Click a lateral edge along the way you want the pattern to go, then enter a number of instances to create (this includes the starting shape), and the spacing between the instances (the spacing between the starts of consecutive instances, not the space between the end of one instance and the start of the next).
This should not update any parameters, because all it does is replicate a feature with specified parameters.
Unread 23-05-2011, 18:10
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
Also, if your total pattern is symmetrical, you can use the mirror button. i think its somewhere next to the trim button. To do this create a construction line (or real line) in the center of the face. Lets say you want two triangles on each side, 5 and 10 in. from the middle. Make the first two triangles on one side.. Then click mirror, then select the triangles. Then click the mirror line button in the little toolbox that pops up. Select that center line, click done, and it will mirror your sketch. This can also work at the 1/4 point,left or right, so youd only have to make one triangle in that situation (assuming the numbers work out fine), and so on. This is very helpful in that you could put one hole on the very end, mirror it by the correct fraction, and then repeat that process until youve hit the 1/2 line. BIG time saver.
Hope this helps,
-duke
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
Unread 23-05-2011, 18:16
lemiant's Avatar
the Dreamer
AKA: Alex
Thanks guys, that helps a lot.
