Go to Post While grandmothers are pretty cool, I would be hesitant in letting them determine what is and is not a robot. - Kellen Hill [more]
Unread 03-06-2011, 18:48
MCeGEAR MCeGEAR is offline
FRC #1243
MCeGEAR is an unknown quantity at this point
Using 2009 code with 2011 windriver
Hello, I am the programmer on team 1243. I started to program right when they switched over to labview in 2010. Our 09 bot was programmed in c++ but the code was erased due to need of it's crio. I have its old code but i can not figure out how to get it to work. When i deploy the old build it saids that it has no code and when i try to rebuild it it gives me many location and decaulse errors.
i have already reformatted the ciro back to c++ and had the simple template run the robot. any help would be very well appreciated, the robot needs to be on display tomorrow.
Unread 04-06-2011, 00:53
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Using 2009 code with 2011 windriver
You may want to try imaging the cRio with the 2009 image, then the old build would probably work.
Without a copy of the code and the complete error messages you get when you try to build it, we probably won't be much help trying to get it to run on the new image and libraries.
Eric Haskins KC9JVH
