Go to Post Silly FIRST mentor -- actually spending brain power caring about a sporting event occuring during build season! - Aidan F. Browne [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 04-07-2011, 17:10
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Solidworks Parameters
Does Soliworks have an equivalent of Inventor parameters, table driven parts and/or table driven iParts. I found these very useful, a good tutorial on their solidowrks equivalents would be great.
Also, does anyone know how to mirror a part. The mirror function in assembly doesn't actually create a mirror image part.
Unread 04-07-2011, 19:05
Aren Siekmeier's Avatar
Aren Siekmeier Aren Siekmeier is online now
on walkabout
Re: Solidworks Parameters
http://help.solidworks.com/2011/Engl...irror_Part.htm is a Solidworks tutorial on creating a Mirror Part. I've done this once or twice, although I seem to remember having some difficulty with the process... Not sure, though, so you could try that.
All I can think of in terms of parameters is equation driven dimensions that act off of global variables shown in the hierarchy tree. It's been a while since I've played with that, and I don't currently have Solidworks installed, so sorry I can't give a more detailed walkthrough. Somehow you create a global variable, and then when you smart dimension something there is the option to make a new equation for that dimension. You might have to look around a bit.
Hope that helps. Hopefully someone else comes along and knows a bit more about those specific features.
Unread 04-07-2011, 23:13
NickE's Avatar
NickE NickE is offline
_
Look into Design Tables. They allow you to specify parameters in an embedded Excel file (you must have Excel installed to use them). We have a few generic gear files that allow us to create gears of any pitch, width, pressure angle or tooth count just by changing a few numbers.
