We are changing from LabView to C++ programming. I've been trying to re-image the cRio to work with C++, but re-imaging keeps failing:
I can image the cRio from another system that has LabView installed, but not WindRiver, so it's not anything to do with the cRio. I haven't been able to image for LabView, Java, or C++. When I do a full re-image (ie Safe Mode off), the imaging seems to work, but the final are where the failure occurs. For a normal re-image, it seems to fail almost right away. I would appreciate any kinds of ideas for how to work out what the problem might be. Thanks. Last edited by duane : 15-07-2011 at 18:01. |
Re: Can't Image cRio
I had to ask the question in order to find the answer.
Thanks to this post that explained the situation with networking on some machines. I was using "one of those machines" that reconfigure the network as the port goes up and down. Inserting a hub between the computer and the cRio fixed the problem. Go figure. Sad. Last edited by duane : 15-07-2011 at 18:52. |
Thanks! |
Done.
if so, ~Make sure that you can either ping or use Measurement Automation explorer. ping 10.xx.xx.another number dont forget your team number once to replace the x's. ~If not please check the wireless. If it is on please turn it off. ~Also please check your firewall. This being on can interfere with the connection between the computer and the c-rio. ~Also you will probably have to power cycle your robot. ~Also make sure your computer is not on "Get connections automatically" please set your computer to for example 10.00.00.99 (replace the zeros with your team's number) ~Also please connect to a router if you havent already. Please tell if any of this works, I havent worked with c++ so I dont know the nitty gritty but this is a start. |
I should have been more clear. I was using the cRio imaging tool, selecting WindRiver C++ and imaging with the latest (v29?) image.
It is sad that this is a problem. Networking should not be that hard. |
