Go to Post Don’t let the medals you win and the trophies on your mantel define who you are. Let it be the lives you’ve touched and the legacy you leave behind. - Sean Schuff [more]
Go Back   Chief Delphi > Technical > CAD
Unread 25-07-2011, 18:41
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
PVC Cad parts?
Hello all, working on a few projects.
Does anyone know where to get CAD files of PVC fittings.
The standard stuff, .5-3 inch, various joints and etc.
Thanks.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 25-07-2011, 22:24
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
Re: PVC Cad parts?
This depends on what CAD package you're using. In Inventor, you won't need to download CAD files. Everything you might need will be found in the "Tube and Pipe" feature on the design tab of the ribbon. For Solidworks or Creo, etc. I can't answer the question.
If you need any help with anything Inventor related, feel free to contact me at msimon@msedesign.net!
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
Unread 25-07-2011, 22:56
Mk.32's Avatar
AKA: Mark
Re: PVC Cad parts?
Well I am working with both SW and Inventor and thanks for the tip.
Looks nice an interesting feature though a looks complex.
I am trying to build a frame for a project out of PVC what would be the best way to do this?
Unread 25-07-2011, 23:03
AKA: Mathew Simon
Re: PVC Cad parts?
Inventor's Design Accelerators may seem daunting to use at first, but once you get the hang of them, I promise you'll never turn back. Never again will I CAD a nut or bolt, a chain, a timing-belt, etc. The piping accelerator is no different. It's actually quite intuitive. If you need help with it, I found a tutorial which thoroughly explains it.
Good Luck!
Mathew Simon
CAD/Design
