Aluminium Gears
Hey CD, I'm looking for any and all COTS aluminum gears on the market. In particular, larger 32DP gears with decent face widths would be really cool. I realize aluminum gears are pricey and hard to find, but I wanna know if CD has any sources I don't know about and couldn't find on a Google search. Thanks!
Re: Aluminium Gears
Sdp-si is the only place I've found aluminum gears at a reasonable price (aside from the limited 20DP selection at AM). Although I've only seem them up to 3/16". What is this for? Last edited by AdamHeard : 27-07-2011 at 14:33. |
Re: Aluminium Gears
I'm interested in prototyping various gearbox arrangements to see if I can save space or weight in small reductions. I also want to test a drivetrain with these gears. I haven't run the numbers on tooth loads, though.
Re: Aluminium Gears
Back when I was on 308 we did aluminum gears in the drivetrain for two seasons (2001 and 2002). I think we used 24 DP in 2002 and they lasted the entire year until the first match of the world championship finals - then they shredded. Pretty bad timing. I think you can find pictures of the gearbox carnage somewhere on this site. In fairness to those gears, we're pretty sure the shaft shifted leaving only about 60% engagement along the face width.
In 2002, those gears were 1/4 inch face width, but we sandwiched multiple gears together to increase the effective face width. I really wish I could remember the source where we bought the gears. Although, as long ago as that was they may not be in business any more. One important note: when we were doing tooth stress calculations, I remember that 24 DP was pretty marginal in later stages of the gearbox, so I would expect 32 to not be able to withstand the loads without getting crazy with the face width. Just be sure to do all of the calculations and double check them. In 2001, we machined custom aluminum gears because we were worried about tooth loads with small gear teeth. I want to say we made them in the neighborhood of 12 to 16 DP. They looked a little weird, but worked great. |
Re: Aluminium Gears
I'm not sure if the Tetrix gearset is worth trying or not, I imagine they are probably pricy. |
#7
Re: Aluminium Gears
The tetrix gears aren't really bad at all in price when compared to other 32DP aluminum gears. a 120 tooth for $30. Now that I know about it, we're certainly interested in doing a 32DP based gearbox for 500 sized motors as 32DP pinions are cheaply and easily available in varied sizes at EVERY hobby shop. I think effective design and pocketing of existing steel gears would yield more bang for your buck than investigating aluminum gears. You should also learn how to calculate gearstrengh using Lewis Bending Numbers, once you do it's trivial to determine if a gear will survive; no need to experiment to solve a problem that's been solved for a hundred years. |
#8
Re: Aluminium Gears
#9
Re: Aluminium Gears
Chris, I wish I could help you out, but our metal shop has been unresponsive recently on account of new business and tied up equipment. |
#10
Re: Aluminium Gears
You'd want to stack thinner gears with both processes, and laser arguably is the faster process for thinner material. |
#11
Re: Aluminium Gears
The tetrix gears are probably 5000 or 6000 series aluminum which is less than ideal for any high torque situation. |
#12
Re: Aluminium Gears
If you've found a bunch of reasonably priced 32dp aluminum gears that just aren't wide enough for your purposes, you can always just stack them. I'm no expert, but that seems to accomplish the same thing, in terms of pressure. Maybe not so much in terms of the statics of the material stress or whatever is going on there, since the gears aren't actually connected, but you're at least distributing the same load over a larger area.
#13
Re: Aluminium Gears
There was a team at CMP that used anodized aluminum gears that were similar to the gearset that andymark sells, i believe they were going to try to start selling them, does anyone else have any more information?
#14
Re: Aluminium Gears
-RC Last edited by R.C. : 28-07-2011 at 17:40. |
#15
Re: Aluminium Gears
And the draft angle.
