Go to Post Improve yourself. Try not to tear others down. - Tom Line [more]
Unread 17-08-2011, 22:43
SKAPP SKAPP is offline
FLL #1439
SKAPP is an unknown quantity at this point
[FTC]: FTC [NewCompetition/Controller]
We are a rookie FTC that received a new FTC competition kit. In the kit, is apparently an updated controller that we are unable to make all the buttons work, with the current Robot C summer license? Does anyone know if their is software upgrade/issue that this new controller is intended for the upgraded Robot C 3.0 or are we just having our own programming issues?
And also, when is Robot C 3.0 being released? Anyone, Bueller... Buller....
Thanks. Not sure how this forum works, where to post questions... etc...
Unread 18-08-2011, 07:17
emmell's Avatar
emmell emmell is offline
Murphy was an Optimist!
AKA: Mannie Lowe
no team (Radbotics, RoboKnights, CircuitRunners, Oscar, and more...)
emmell is just really niceemmell is just really niceemmell is just really niceemmell is just really niceemmell is just really nice
Re: [FTC]: FTC [NewCompetition/Controller]
From an email blast sent out to FTC Teams: "ROBOTC 3.0 will be available on August 31st.... To order your copy of ROBOTC, please go to http://www.ROBOTC.net/ftc".
I don't know the details of the new controller.
Mannie Lowe
FIRST Program Manager - Center for Mathematics and Science Education - University of Mississippi
Mississippi FIRST Tech Challenge Affiliate Partner
Unread 05-09-2011, 17:34
normalmutant's Avatar
normalmutant normalmutant is offline
AKA: Nathan
FTC #3539 (Say Watt?)
normalmutant has a spectacular aura aboutnormalmutant has a spectacular aura about
It is still an NXT brick, correct? If it's not working, then use RobotC to re-install the firmware. If it's a hardware problem, you may need to call for a replacement.
However, what's most effective is asking an experienced team near you to help you set everything up in person.
SAY-WATT.ORG
Unread 07-09-2011, 16:33
alanlevezu alanlevezu is offline
Coach/Mentor
no team (Techno Guards)
alanlevezu is an unknown quantity at this point
Originally Posted by SKAPP View Post
In the kit, is apparently an updated controller that we are unable to make all the buttons work.
By controller, did you mean joystick?
If it's something other than the standard logitech one (http://www.logitech.com/en-us/gaming...s/devices/288),
then you're the first to report it!
If that's the one, then all the buttons work unless you've got the wrong joystick driver!
Alan LeVezu
No team anymore! Now just in NorCal!
(Coach - Retired FTC Team 2848: Techno Guards)
Unread 07-09-2011, 18:34
ssi ssi is offline
AKA: David Spangler
FTC #2843 (Under the Son)
ssi will become famous soon enough
There is a switch on the bottom of the new Logitech controllers that can be set to either "X" or "D". Set the switch to the "D" position and try again. This should give you access to all the buttons. Note: If you change the switch after you enter RobotC, you will have to re-scan for controllers.
