Go to Post I tell my friends that the robot is the kids product and the kids are the mentors product. - rwood359 [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 27-08-2011, 03:10
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Python WPILib Reference?
Hello there,
I'm looking to try out programming in python, but I can't figure out what functions/classes/etc exist. Is there some sort of simple reference that lists the functions, parameters, returns, and a sort description of what they do? Or is there a file in the robotpy folder that defines them? Going off examples involves a lot of guesswork, which is tough without a C-RIO.
I did find something that says, "They're basically the same as the c++ ones but some of them are different" which wasn't very helpful, especially since I don't know the c++ functions! If anyone has a page on the c++ functions, that would be nice also.
Thanks for the help!
Unread 28-08-2011, 00:25
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Re: Python WPILib Reference?
It's available in a couple of places online (just search for "WPILib reference"):
http://devildawgs549.com/2011_WPILib...Reference.html
http://amhsrobotics.com/wpilib/html/annotated.html
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 28-08-2011, 03:58
WizenedEE's Avatar
AKA: Adam
Thank you, those look great.
Is there a place where I can look at the source code of all the wpilib python functions, somewhere in the robotpy file that's on github?
Unread 29-08-2011, 00:09
WPILib Developer
The Python WPILib is mostly just a wrapper around the C++ one, generated by a tool called SIP (this is unlike Java, where the Java WPILib is written entirely in Java itself). The code is located in https://github.com/robotpy/robotpy/t...ackages/wpilib
The wpilib.py file is what you get when you "import wpilib", and is the only real Python file. It reimplements the robot base classes (e.g. IterativeRobot) for technical reasons (the C++ robot class runs the Python interpreter so you can't overload it directly from Python).
The rest of the library is implemented through code generated from the sip files in the sip/ directory. These are (for the most part) just stripped down copies of the C++ header files with a few tweaks where necessary to support reasonable parameter passing to and from Python.
Unread 03-09-2011, 00:26
Ziv Ziv is offline
Has code to be writing...
FRC #0125 (Nutrons)
Ziv is a glorious beacon of lightZiv is a glorious beacon of lightZiv is a glorious beacon of lightZiv is a glorious beacon of lightZiv is a glorious beacon of light
Peter, thanks for bringing Python to FRC!
I poked around for a while in the links you mention, but I still have one question: does one need to do anything special to specify values of types such as EncodingType? Is the proper syntax just "enc = wpilib.Encoder(1, 2, False, k4x)" or something fancier?
Unread 04-09-2011, 00:06
WPILib Developer
Constants are scoped into the class where they are defined. E.g. "wpilib.Encoder.k4x", "wpilib.Relay.kReverse", etc.
Unread 24-09-2011, 20:42
DjMaddius's Avatar
DjMaddius DjMaddius is offline
AKA: Matt Smith
FRC #2620 (Southgate Titans)
DjMaddius is an unknown quantity at this point
Are we allowed to use Python this year? That would be incredible! Python is easily on the top of my favorite languages. It makes things that would normally take lots of code in one language into just a few short lines.
If we can use Python, we are all set this year. Not a fan of labview D:
Unread 25-09-2011, 00:27
WPILib Developer
Until the 2012 game manual is released, we won't know for sure, but all indications are that it (and other scripting languages like Lua) will be legal. One positive indication: both teams 294 (ported Python) and 973 (ported Lua) are control system beta testers for 2012.
Unread 25-09-2011, 13:38
DjMaddius's Avatar
AKA: Matt Smith
Awesome! Really looking forward to it this year. Thanks for the info.
Unread 26-09-2011, 15:05
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
We used python last year, it was fantastic.
Unread 26-09-2011, 15:46
DjMaddius's Avatar
AKA: Matt Smith
Been talking with the others involved and it looks like we are going to do Labview and python parallel together this year! Im doing the python and one of the mentors is doing labview. He prefers labview because he did it at Comau.
Really looking forward to my third year programming for the team! Im glad their is a nice community on python now. I had no idea the opportunity was there last year.
