Match Results API from team 862
Behold, the Lightning Robotics Match Results Retrieval System, version 1.2p. Seeing as the Blue Alliance API is no longer supported, we decided it would be an amazing idea if we created our own php-based system for displaying match results.
This system allows you to retrieve your team's match results in real time as your competitions unfold, and display them on your website. It allows parents and those who can't make it to your competitions to see your match results without the clutter of other teams' matches. It will even auto-update in their browser. You can read about, and download, the system here. If you have any comments, questions, or suggestions, I'd love to see them! Especially if you manage to improve the system! To see the system in action on our own site, go here. I did my best to make this NOT sound like an advertisement. How'd I do? EDIT: Updated to version 1.2p. Last edited by quinxorin : 03-09-2011 at 19:07. Reason: changed post title to be more useful |
Re: Match Results API from team 862
Looks good, this should make it easier for other teams to keep track of match data on their sites, I DEFINITELY recommend they try it out.
Re: Match Results API for your website
Yeah, this looks very cool and convenient. I'll be sure to check it out when I get a free couple of hours.
I really like the functionality, but the IMHO the display on your website is a bit tacky. Maybe some rounded corners or AJAX refresh would help.
It works by loading a cached copy first, then uses AJAX to replace it with an updated version once the server is done scraping it from FIRST. It then refreshes automatically every 60 seconds. If you click the "Refresh" link (which disappears once the AJAX does it's thing) it will force the page to be updated server-side before being sent to the browser. It doesn't normally scrape before transmitting due to the several-second lag caused by scraping the data from FIRST. Also, that very obvious notice about our team's first meeting isn't normally there, obviously. That makes it look rather ugly. Last edited by quinxorin : 04-09-2011 at 20:13. |
This is a good point, I'm glad you brought it up. Last edited by quinxorin : 04-09-2011 at 20:54. |
#8
You other option, and one I just never got around to implementing, would be to check the Last-Modified header and see if it has changed since your cached version.
#11
Version 1.3p
I just updated the system to version 1.3p. The previous discussion about scrape times made me realize (about five minutes ago) that the scrape time limit was per user, so if ten people were viewing the page, then it would scrape ten times as fast, even though each individual user would still see it only as often as the scrape time permitted - an obvious flaw. But it's fixed now, and the system will not scrape data from FIRST if it hasn't been long enough.
I kind of hurried this out, so it hasn't had the proper bug testing. It was a simple change and shouldn't have caused any, but if anything stops working, please tell me. Another minor change: the "last updated on" notice is now at the bottom, not the top. There have been fifteen downloads at the time of this posting. Unfortunately, that still means that the connecting has to occur, because the header isn't sent from FIRST unless an http request is sent. The only benefit of using that header, that I can think of, would be to reduce load on the server implementing the API, because then it wouldn't have to process the data. If you look at the function library, it uses a seriously ginormous number of string operations and array manipulations. Am I totally wrong about the usage of that header? Last edited by quinxorin : 04-09-2011 at 22:27. |
#13
This is great!
My question, however, is regarding the number of events you can have. PHP Code:
Thanks again for coding this! |
#14
It does work with just three, right? Try the following: 1. Make sure that your team number is properly defined in the config file. It should read: PHP Code:
PHP Code:
3. Check to make sure the www2.usfirst.org domain is online. They must be doing some upgrades or something, because it seems to be going down for short periods every few days, or at least it did when I was building this system. It got frustrating. 4. If it's still not working, add the following line to the top of the matchresults_config.php file: PHP Code:
PHP Code:
PHP Code:
Normally, you'd use matchresults_viewrecord.php. When testing, try using matchresults_output_show.php. That is the most basic one - it won't use AJAX Refresh or even save to the cache, just get you your data. Last edited by quinxorin : 08-09-2011 at 15:59. |
#15
Yes, it works with just three! I didn't mention that!
Everything was correctly configured, and the page matchresults_output_show.php did show all 4, so my guess is that the cache process doesn't work on my server (shared hosting with Arvixe.com). My PHP configuration is Memory_limit = 256M, max_execution_time = 600 |
