Go to Post Although I'm 2-0 against 217 when Paul coaches, I'm 0-2 against them when he doesn't....hmmm.... :rolleyes: - Lil' Lavery [more]
Go Back   Chief Delphi > Technical > CAD
Unread 06-09-2011, 16:57
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Chassis - Team 772 2011 off-season (update)
I finished updating the chassis.
Old thread is : http://www.chiefdelphi.com/forums/sh...ad.php?t=97193d
Gen2 Andymark transmissions
6WD (IFI 6" diameter 1.5" wide)
1/8" sheet metal
0.75" flanges for structural support
Direct drive to middle wheel
Changes:
Sheet metal to 1/8" from 0/09"
Put supports across transmissions
Moved Back/Front plates to outside
Put Belt pulleys onto wheels
inserted Hub onto middle wheel for direct drive
Made a few more flanges for structural support (note: could not put too many on bottom because the belts would rub against them)
Frame weighs 9.27 pounds without motors or transmission.
Chassis total weight is 27.35 pounds
Any more questions or Tips for improvement are appreciated.
Name:	sexy in studio_2.JPG
ID:	10913  Click image for larger version
Name:	sexy in studio_3.JPG
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 06-09-2011, 17:26
Chris is me's Avatar
AKA: Pinecone
Re: Chassis - Team 772 2011 off-season (update)
I don't understand the point of the material below each wheel.
Unread 06-09-2011, 17:34
Colin P's Avatar
Colin P Colin P is offline
MTU Robotic Systems Enterprise
AKA: Colin Putters
FRC #0857 (Da Yooper Troopers 3771, Unbolted Puppeteers 4363)
Colin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to behold
Style points
Unread 06-09-2011, 17:49
Bumper support? Your not the first person to ask me this, but yes it mainly is just for looks. They dont add alot of weight, but i may remove them.
Edit: I just remembered the real reason. They are supporting the transmissions on the inside
2013-Present
2010-2013
Unread 06-09-2011, 18:10
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
The transmissions are too low to the ground to allow you easily and legally mount bumpers to the side plates. I'd still recommend raising everything up to reduce your ground clearance.
Additionally, by removing the trapezoids from the side plates, you can add another flange along the length of their lower edge and make everything stiffer. Right now, the trapezoids do nothing but hurt you.
--Madison--
...down at the Ozdust!
Unread 06-09-2011, 18:28
The picture shows how the transmission is mounted to the side plate. If i remove the trapezoids, the bottom two supports will not be held on by anything. However, by moving the transmissions further up and removing the trapezoids, the two Top supports now would have nothing to hold onto, unless i change the sheet metal design (also changing wheel height). I could change how close the trapezoids extend to the floor (shorten them by 0.5"), make some flanges on the bottoms of the trapezoids and then the floor clearance would be about 1" (currently .5"). Would this be a better alternative?
2013-Present
2010-2013
Unread 06-09-2011, 19:02
Madison's Avatar
FRC #0488 (Xbot)
You want to change the sheet metal design -- by moving the gearbox up and changing the wheel, you'll lower the entire frame neared to the ground. Since a typically legal bumper height is between 1-7" or so from the ground, that puts the frame in the sweet spot.
Flanges on the bottom of the trapezoid won't really do anything useful to make the frame stiffer. A flange that runs, uninterrupted, along the entire bottom length -- just like you have on top -- is the most rigid solution.
--Madison--
Unread 06-09-2011, 20:18
I'll have the design changes up by tomorrow hopefully.
How much ground clearance should I make it? Im thnking 1 inch so the bumbers are even with bottom or robot. Should it be loweror higher?
2013-Present
2010-2013
Unread 06-09-2011, 20:38
Madison's Avatar
FRC #0488 (Xbot)
1" is probably fine. The bumper rules will usually reflect the sort of field the game is played on -- so if the field is largely flat or if it has only gentle inclines, the typical 1"-7" bumper zone will work fine. If robots are expected to navigate steeper ramps, additional ground clearance is required and the bumper zone will reflect that.
--Madison--
Unread 06-09-2011, 22:29
Red face Re: Chassis - Team 772 2011 off-season (update)
I finished faster than i thought. The new chassis is actually heavier than the old one. The new weight is about 0.5lbs more.
Name:	New Chassis.jpg
2013-Present
2010-2013
Unread 06-09-2011, 22:41
Looking good! Now you'll need to add some material to that center wheel's mounting hole and add a bearing so it can be direct driven.
Unread 06-09-2011, 23:15
Here is how i did the direct drive to the middle wheel.
Basically, the output shaft is connected to the hub (keyway) which is inside the wheel and bolted on. I put a support axle on the other side which is inside the bearing on the wheel.
Will it work? Or is this a bad idea?
Name:	Drawing for direct drive.jpg
2013-Present
2010-2013
