Go to Post These predictions are just a bit of fun. Neither these, nor the division threads, are meant to be comprehensive. Don't like 'em? Go out there and prove them wrong! - Looking Forward [more]
View Poll Results: Which is better: Performance wheels or Plaction wheels?
Performance Wheels 14 48.28%
Plaction wheels 15 51.72%
Voters: 29. You may not vote on this poll
Unread 11-10-2011, 23:26
Andrew Lawrence
Posts: n/a
Performance wheels vs. Plaction wheels
Which do you prefer: Performance wheels or Plaction wheels? Why do you like one over the other?
Thanks!
Unread 11-10-2011, 23:39
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Performance wheels vs. Plaction wheels
Better how?
Plaction price is right and they perform well but performance wheels are cooler.
Unread 12-10-2011, 00:04
Andrew Lawrence
Posts: n/a
Originally Posted by IndySam View Post
Better how?
Better overall, in your opinion. And I agree, performance wheels have that coolness factor about them.
Unread 12-10-2011, 01:32
Ankit S.'s Avatar
Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
Edit 2: Disregard what follows, I thought performance wheels were something else.
For some reason, I just like the plaction wheels. For that same reason, i just don't like performance wheels. I can't explain it, but i think i like plaction wheels because they are great in traction, size, and weight. I think i dont like performance wheels because I prefer mechanums over them to do fancy tricks...
Now don't get me wrong, they both(performance vs plaction) have their advantages and disadvantages, but imo, plaction all the way <3.
EDIT: Ill think about why its like this, and if you want a better answer, hit me up at CalGames .
FRC 2489 - The Insomniacs
Alumnus
2489, 3189, & 701 - The Green Alliance - 2013 Sacramento Regional #6 Alliance Captain and Champions!!!
971, 254, & 2489 - 2011 CalGames Champions. Thanks 254 and 971!!!
Last edited by Ankit S. : 12-10-2011 at 21:03. Reason: Thought Performance wheels were something else...
Unread 12-10-2011, 01:34
Plaction vs Performance has nothing to do with what you mean by fancy tricks.
Your tread it what gives you traction, not the wheel the tread goes on.
Unread 12-10-2011, 03:52
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
Exactly. There is absolutely no difference in terms of traction. The CoF will remain subject to the tread riveted TO the wheel. The way I see it, this is an aesthetics vs cost question. While the Performance wheels have an obvious aesthetic advantage - this is undeniable, - they cost $36 / piece (with bearings). This is compared to $26 for the Plaction wheels.
In my personal opinion (and I should say that I will almost always be biased towards aesthetics), they $10 per wheel extra to get the aluminum Performance wheels is definitely worth it. Compared to the overall cost of your robot, $10*[# of wheels] is probably a minute amount of money.
That said, there are definitely situations, ie. a practice bot, in which case there would be no reason for the additional expenditure, given that the robot will likely never be in the public eye.
Just my 2 cents.
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
Unread 12-10-2011, 04:07
It is not all aesthetics.
The plaction wheels are easier to use in a drive setup in which sprockets are mounted to either side of the drive wheel whereas performance wheels with hex or key in them are easier to use for let's say a WCD system. Performance wheels have a bolt pattern on only 1 face, so you would have to double mount sprockets in order to run the most common 6wd setup. Each wheel has its benefits. The plaction wheels require a hub if you wish to direct drive, where the performance wheels are broached if desired.
It depends on what you are designing, there's no real "which is better?" in most cases of wheel selection. Tread selection is another issue though.
Unread 12-10-2011, 12:34
Chris is me's Avatar
AKA: Pinecone
This isn't entirely true. We had measurably more traction from our Performance 4 inch wheels than our Plaction 6 inch wheels. I suspect it has something to do with the Plaction's deep tread groove.
Unread 12-10-2011, 13:01
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
For a directly driven wheel, a performance wheel is cheaper and lighter than a plaction wheel + AndyMark hub.
Unread 12-10-2011, 13:14
Mr. B's Avatar
Mr. B Mr. B is offline
FRC #5122 (RobOTies)
Mr. B is an unknown quantity at this point
We had the same problem as team 176 listed above. Wire ties and rivits helped us get through the competition
Unread 12-10-2011, 14:09
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Both wheels fall into the same category: COTS wheels with replaceable tread. This category also contains the IFI/VEXPro wheels. They all provide the ability to mount up treads of your choice.
For prototyping purposes a set of Plaction wheels will allow you to try different axle sizes (1/2" or 3/8") by switching just the bearings and testing live vs. dead axles (hex or keyway) with the addition of hubs.
I like the flexibility in testing that Plaction wheels offer, but for a competition robot with a defined drivetrain the Performance wheels would be my choice (that is, if i wanted treaded wheels and was happy with only a 1" tread width)
Unread 12-10-2011, 14:15
AKA: Pinecone
FWIW, IFI wheels are pretty much the same in this regard.
Unread 12-10-2011, 14:51
Colin P's Avatar
Colin P Colin P is offline
MTU Robotic Systems Enterprise
AKA: Colin Putters
FRC #0857 (Da Yooper Troopers 3771, Unbolted Puppeteers 4363)
Colin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to behold
You would've been getting more torque from a 4 inch wheel than a 6 inch wheel, but I'm going to assume you knew that and agree with you that performance wheels edge out the plaction wheels due to that groove design.
Unread 12-10-2011, 23:43
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
In my view, weight will determine 90% of all debates with all other things equal.
My team normally pairs up some sort of high-traction wheel with omni-wheels (we call them the "your momni-wheels"). We've never had a problem with the plaction wheels from AndyMark, so while the performance wheels are nice and pretty, we normally cover them with bumpers anyways, so we go with the lighter choice (rated 0.8 lb performance vs 0.66 lb plaction). It's not an outstanding difference, but sometimes every little thing counts.
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
Unread 01-12-2011, 09:39
Andrew Lawrence
Posts: n/a
Are both the performance wheels and the placation wheels the same size? I mean if you had the same size of each and put them right next to each other, will they be the exact same? If not, is it because the wheel frame itself is bigger, or because the tread protrudes out farther?
