Go to Post I love it when someone tells me I can't do something. - dlavery [more]
Unread 14-10-2011, 08:59
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
HELP!!!!!!!! with Labview Errors
Im geting a error within the FPGA_ReadAI.vi that is within the hiearchy of the Build Dashboard Data.vi on the FRC 2011 Crio Project this is frustrating as the code worked until i added a Encoder Reset function into Begin.vi. I also have gatten a error within the code in which to vision processing is done and the WPI_CameraIssue HTTP ... .vi. can you help and i dont know how to post the code.
Thanks in advance
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 14-10-2011, 12:17
Larry Lewis's Avatar
Larry Lewis Larry Lewis is offline
The Spiky Hair Guy
FRC #1511 (Rolling Thunder)
Larry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to all
Re: HELP!!!!!!!! with Labview Errors
Could you post a screen shot of the error you are getting it may help others understand the issue better. Just do a Alt+PrtScn with the window selected. Then open paint and paste it into a jpg file. Finally attach it to the reply post using the attach button.
Larry Lewis
FIRST Team 1511 - Rolling Thunder
Team Leader
2013 - Present: Systems Engineer - Viewpoint Systems
2004 - 2013: Lead Test Engineer - Harris RF Communications
www.penfieldrobotics.com
Certified LabVIEW Architect
"I haven't failed, I've found 10,000 ways that don't work" ~Thomas Alva Edison
Unread 14-10-2011, 16:53
inkspell4's Avatar
I will try my best but it will have to wait till Monday as the robot is at school
Unread 14-10-2011, 20:20
As mentioned, please post more info, but my guess is that in Begin, some form of I/O based on the FPGA is no longer opening due to the latest modification. Without more of the error chain, it can't be narrowed down. I'm not really sure why the error is first showing up in the prep dashboard code except that it reads virtually everything in it's current form. If this is how the tea leaves dry out, focus on fixing the open error and all should work fine.
Greg McKaskle
Unread 17-10-2011, 10:23
inkspell4's Avatar
Thanks for trying to help but it was all because our crio had image v28 not v30
Unread 17-10-2011, 13:09
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
It's great that you posted the solution to the problem, as then you and other teams can be sure to add 'Check version of FPGA image' to their trouble-shooting check-list.
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 17-10-2011, 15:44
inkspell4's Avatar
Sounds Like a good idea and if you have one of these trouble-shooting check-lists could you please post it here as we are a new veteran team but our rookies in the labview programing language and just lost our only programer(don't ask me why we only had one i have no idea but we were a very small team)
