Go to Post If you don't like contact, your robot is not built well enough. - sanddrag [more]
Unread 22-10-2011, 12:21
George C's Avatar
George C George C is offline
AKA: George Chisholm
FRC #1360 (Orbit Robotics)
George C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to behold
#25 aluminum sprockets
Anyone had any problems with smaller #25 (20T to 30T) aluminum sprockets stripping while in use in a drive train?
Unread 22-10-2011, 13:17
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: #25 aluminum sprockets
Many people use #25 aluminum sprockets with great success. I'd recommend the 7075 ones from AndyMark.
Unread 22-10-2011, 13:49
ttldomination's Avatar
Sunny
We've been using the smaller sprockets for a couple of years now, and we've never had a stripping problem. You have to be careful and make sure that the sprockets are almost perfectly spaced, or else you're going to be in a world of hurt.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 22-10-2011, 14:02
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
- Sunny G.
Also, make sure they're aligned correctly and won't wiggle around much while in use (not only will the chain probably skip a little bit, but you may end up starting to strip them a little bit). As long as you aren't sloppy about securing/spacing/using them, and keep checking to make sure they are still secured, you shouldn't have any problems.
The only problem I've ever had was when a bolt came loose during a match, and our sprockets ended up skewing every which way while we tried to figure out why that side of our drivetrain wasn't working. The result, after the sprocket was removed from the hub it was welded to:
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 22-10-2011, 15:11
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
I've only seen damage done to plastic sprockets, and even then, splitting not stripping.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
