Go to Post Achieving a goal by merely finishing, or reaching mediocrity is not acceptable; Excellence is the only satisfactory result. - AdamHeard [more]
Unread 05-11-2011, 10:25
austin1743 austin1743 is offline
Head Programmer - Java
FRC #1743
austin1743 is an unknown quantity at this point
Java Programming learning?
Hello, so my team has a bunch of people interested in learning how to program in java. Some have taken a course on it for desktop applications and understand how it relates to the robot (from me telling them how) but what we lack is a way to teach new programmers how to well put simple learn to program. Can anyone recommend a good java programming book or website, or tutorial that is closely related to the programming used here?
thanks
Unread 05-11-2011, 11:46
Re: Java Programming learning?
http://first.wpi.edu/Images/CMS/Firs...va_for_FRC.pdf
Unread 06-11-2011, 07:34
FRC #1743
thanks Ether, I and the my teams programmers will read through the document and learn it. thanks.
To get people interested in java, what book would you recommend for them to read that introduces java really good?
Unread 06-11-2011, 07:55
This is my personal favorite:
http://www.amazon.com/Java-Tutorial-.../dp/0321334205
also this website:
http://download.oracle.com/javase/tutorial/
Unread 06-11-2011, 15:06
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
My AP Computer Science is using Blue Pelican Java. http://www.bluepelicanjava.com/bookDescription.htm I like it a lot.
Unread 06-11-2011, 17:33
FRC #1743
Thanks guys, I will look into them.
ether, thanks i will show these to the programming team thanks again.
cgmv123, thanks and i will look into bluej, i have heard of it but haven't actually used the IDE...
just to make sure, does it matter what ide you use to code java?
thanks everyone
Unread 07-11-2011, 01:16
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
Hi,
The book I learned java from that I thought was great (and that the people interested in learning programming on my team are using) is Headfirst Java (http://www.amazon.com/Head-First-Jav.../dp/0596009208)
I think it does a great job of not being a boring programming book that you have to push yourself through.
In terms of IDEs, my AP CS class used BlueJ as well (which quite frankly I didn't like too well). I ended up using netbeans in class. Netbeans is also the IDE that FRC uses, while it probably has a steeper learning curve than BlueJ using it at first avoids the dreaded IDE switch that your programming guys will have to endure when the season starts. I also think that it is more full featured and will acclimate your programmers better to IDEs that are used outside the educational world that BlueJ was designed for.
Oliver
PS These books are written for Java SE, whereas the robot uses Java ME which lacks a lot of conveniences, however some things are easy to re-implement, ex Lists
Unread 07-11-2011, 17:28
cgmv123's Avatar
AKA: Max Vrany
BlueJ and Blue Pelican Java are unrelated apart from the fact that the book's author recommends BlueJ as an IDE. You can use one without the other.
You can program Java using Notepad or a similar text editor if you want. The only difference is how it works. It doesn't matter what IDE you use and you don't even need an IDE.
Unread 07-11-2011, 18:45
FRC #1743
Thanks linuxboy for the recommendation of the book, i will look into it.
cgmv123, thanks, that's what i originally thought originally. I started learning java without an IDE but gave up on that when i got recommended netbeans. But i will give all IDe's a shot...
Thanks everyone for the advice on books to learn java. I am looking into all of them with intent on becoming a great programmer.
I will post here if i got anymore questions, thanks
Unread 10-11-2011, 21:43
FRC #1743
I started using the BlueJ IDE and found that i can compile the code but have yet to run any... How do you run them in bluej to see if they work?
All i get is that my syntax is correct ( of course it is) but i cant seem to get it to appear anywhere. I reread the book and couldn't find a location of how to run it...
Team 1743
Head Programmer
Unread 11-11-2011, 07:17
cgmv123's Avatar
AKA: Max Vrany
Right-click the class in the main window and click your main method. (Usually "public static void main(String args[])" A window will pop-up where you can enter arguments. Most of the time you can just click OK.
Unread 11-11-2011, 07:28
FRC #1743
thanks
Team 1743
Head Programmer
Unread 11-11-2011, 13:02
Bacon8er Bacon8er is offline
AKA: Brian Walters
FRC #1902 (Exploding Bacon)
Bacon8er is an unknown quantity at this point
Check out: http://www.goodsky.tk/vg/
This tutorial was put together by Exploding Bacon's programming mentor. It holds the attention of students by keeping it simple and making games, and Skyler is a talented teacher!
Unread 19-11-2011, 00:29
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
Another good one that is helpful because it doesn't just sound like a stereo manual is Java for Dummies (I believe the current edition is 5). Amazon doesn't want to cooperate with my computer right now so I can't get a URL for you.
The oracle documentation is also helpful, but more for details on particular methods than learning with.
