Go to Post Past success does not guarantee future results.... - Koko Ed [more]
Unread 09-11-2011, 16:55
stuart1086 stuart1086 is offline
FTC #1086
stuart1086 is an unknown quantity at this point
ROBOTC servo code fails after update
So, we had some code that displayed servos and their capabilities. After reimaging the computer and reinstalling a new version of ROBOTC, our program wouldn't work. We tried everything, programming, electrical, or otherwise. This is the elementary program we created to test if servos would move at all:
#pragma config(Hubs,  S1, HTServo,  none,     none,     none)
#pragma config(Servo,  srvo_S1_C1_1,    motor1,               tServoNormal)
#pragma config(Servo,  srvo_S1_C1_2,    motor2,               tServoNormal)
//*!!Code automatically generated by 'ROBOTC' configuration wizard               !!*//
task main(){
  while(true){
    //Bend it one way, wait, bend the other way
    servoTarget[srvo_S1_C1_1] = 120;
    servoTarget[srvo_S1_C1_2] = 120;
    wait1Msec(1000);
    servoTarget[srvo_S1_C1_1]= 0;
    servoTarget[srvo_S1_C1_2]= 0;
    wait1Msec(1000);
Is something wrong with this? Or is it ROBOTC? We have ROBOTC version 1.40.
Unread 09-11-2011, 21:29
Matthew Blake's Avatar
Matthew Blake Matthew Blake is offline
FRC #3481 (Bronc Botz)
Matthew Blake is an unknown quantity at this point
Re: ROBOTC servo code fails after update
Have you tried making sure the CRIO Firmware is up to date?
Have you tried making sure the Driver Station Software is up to date?
FTC Team 4008: 2009-2012
FTC Team 4602: 2010-2012
FRC Team 3481: 2010-2012
Unread 11-11-2011, 16:11
FTC #1086
This is FTC, not FRC. No CRIOs over here, just NXT bricks.
Unread 12-11-2011, 15:21
Ah sorry, my mistake.
Have you tried updating the firmware on your NXT Brick?
Use a USB Cable to connect the brick to your computer with ROBOTC on it and try updating the Brick's firmware. Our team recently had a problem with our NXT Bricks and updating the firmware seemed to solve it.
Unread 12-11-2011, 15:56
Did you try posting to the FTC forum ?
Unread 12-11-2011, 18:09
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Did you download the new RobotC firmware to the controller?
We've found that the RobotC versions must have the right firmware.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 13-11-2011, 20:52
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
LONG story, but we figured out our problem.
Here's some insight to the issue: Version 1.4 doesn't play well with Tetrix. Version 3, on the other hand, plays nicely with the hardware.
Thank you all for your replies.
