Physics Quiz 3
This is a continuation of the Physics Quiz posted here yesterday: The problem is changed as follows: - The wheel is rotating about its axis at a constant rate omega_w - The (constant) torque exerted on the wheel by the motor is tau_k - The wheel+motor assembly is revolving CCW around the pivot at a constant rate omega_p - The length of the connecting rod is L - The weight of the wheel+motor assembly is W - The coefficient of kinetic friction between wheel and floor is mu_k What is the magnitude and direction of the floor's friction force on the wheel? |
Re: Physics Quiz 3
Is the majority of information given not needed?
f = μN = μmg = (mu_k)(W/g)(g) = (mu_k)(W) |
Re: Physics Quiz 3
I would say the majority of the information given is needed. It just might not be needed for a particular part of the problem. |
Re: Physics Quiz 3
Well isn't friction always opposite the applied force?
Re: Physics Quiz 3
So what's the "applied force" ?
Caution: think this through. |
Re: Physics Quiz 3
I wanted to think about this kind of extension after I figured out part one, but I had to learn how to drive instead.
I'm going to go very slowly... and try to not be too confused... 1. Centripetal acceleration is constant so: Centripetal force on the wheel = (WL/g)(omega_p)^2 = Tension in the rod - Friction parallel to the rod 2. Tangential acceleration is zero, so net force perpendicular to the rod is zero. 3. And I think brndn was right in saying F=(mu_k)(W), yes? 4. And then friction parallel plus friction perpendicular would still equal tau_k/(rsintheta) if there was no wheel slip. However, there is wheel slip, which is why point 2 is true. So, the only forces are tension and friction parallel, so friction is anti-parallel to the rod. At least I think so...? Is there another way to get the magnitude of friction using the difference in wheel speed and rod speed? Last edited by Ninja_Bait : 19-11-2011 at 14:45. |
#7
Re: Physics Quiz 3
The magnitude of the centripetal acceleration is constant, but the centripetal acceleration vector is not constant because its direction is changing.
Tangential acceleration is the rate at which the tangential velocity is changing. Since the tangential velocity is not constant, the tangential acceleration is not zero. |
#8
Re: Physics Quiz 3
In this problem the radius is constant and d(theta)/dt is constant as well. That means that angular acceleration is zero and tangential acceleration is also equal to zero. (Maybe the problem is my axes. I created another system where one axis is always perpendicular to the rod and the other is always perpendicular. Then the centripetal acceleration is actually constant in both direction and magnitude, and I think tangential velocity is also actually constant) Last edited by Ninja_Bait : 19-11-2011 at 16:36. Reason: I had an extra thought. |
#9
Re: Physics Quiz 3
I'm thinking one of us needs to build this (massless rod might be tough to find...) and put a piece of paper under the wheel and see which way the paper flies.
#10
Re: Physics Quiz 3
Since the tangential acceleration is zero, the frictional force must act in the direction of the rod (so it must be angle theta from the horizontal).
The forward friction force on the wheel must be equal to tau_k/r or the wheel would not be spinning at constant speed. The sideways friction force for the friction to act in the correct direction must be equal to forward friction * tan(90 - theta) so the total friction force would be tau_k/r * sqrt(1 + tan(90-theta)^2) = tau_k/r * sqrt(sec(90-theta)^2) = tau_k/r * sec(90-theta) = tau_k/r * cosec(theta) = tau_k/(r*sin(theta)) |
#11
Re: Physics Quiz 3
Yes.
But according to the Coulomb friction model, the total friction force must be mu_k*W. So that means tau_k must equal mu_k*W*r*sinθ. So, what happens if the voltage to the motor is increased? |
#12
Re: Physics Quiz 3
@ Ether: Sorry to confuse you; I accidentally hit submit instead of preview and had to go back to finish editing. :\ Lesson learned in clarity of answer as well. However, I'm glad I was right about direction. That makes everything better. I'm very interested by John's last answer. It seems that friction is always tau/(rsin(theta)) and parallel to the rod, pointing away from the pivot, no matter the conditions. Is that the end result? |
#13
Re: Physics Quiz 3
http://www.chiefdelphi.com/forums/sh...0&postcount=12 |
#14
Re: Physics Quiz 3
@Ninja_Bait:
My apologies, I misunderstood your earlier post. I see you edited it. I had the original version still on the screen when I replied to it (got interrupted). The net force acting on the motor+wheel assembly points directly to the pivot. This must be the case, since the angular acceleration is zero (the problem stated that the angular velocity is constant). The net force is equal in magnitude to the tension minus the friction. Since these are the only two external forces acting on the motor+wheel assembly, the friction must be pointing directly away (radially) from the pivot. As posted earlier, the magnitude of the friction force is simply mu_k*W (if we assume the Coulomb friction model). |
