Help mapping PSoC 3 GPIOs
So our team got a PSoC and I need help mapping out the GPIOs. This is what I got so far.
P0_0-7 controls Analog Inputs 1-8 respectively. P4_4-7 controls Digital 1-4 respectively. P6_0-3 controls Digital 5-8 respectively. Aside from that, I have no idea what the other GPIOs do. Anyone know? |
Re: Help mapping PSoC 3 GPIOs
Does this help?
Cypress IO Pinout tables.pdf Did you just purchase Your PSoC? If so do you know what model it is? You may have a problem with the latest model working cooperatively with the FRC Driver Station application. ![]() Last edited by Mark McLeod : 19-11-2011 at 21:55. |
Well that I know, I'm just trying to figure out the function of each one on the Driver Station itself when programmed with FRC's firmware
You must have seen this Enhanced mode from the Driver Station I/O tab then?
The default Compatible mode doesn't access all the Cypress capabilities. Compatible refers to the original 2009 Linux blue-box Driver Station I/O pins. ![]() ![]() ![]() Last edited by Mark McLeod : 20-11-2011 at 09:47. |
I indeed have seen the enhanced tab, but it never occurred to me that the below picture also states with pin is what.
Thanks a bunch! |
