Go to Post FIRST... (is) just as human as we are. (except now in game hint season when they are big meanies) - Tetraman [more]
Unread 22-11-2011, 07:15
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
Confusion with turning
I want to program with LabView this year, so I started learning it online. During the simple autonomous lesson where you set the speeds for the motor, I am really confused about the x and y speed inputs. If x=0.25 and y=0.5 then it turns right and if they are reversed, it turns left??? This doesn't really make sense. Is it turning with no forward movement or still moving forward, just turning a little?
Name:	turn right.JPG
Unread 22-11-2011, 09:29
Re: Confusion with turning
The y value tells Arcade to move forward at half speed while the x tells it how much to turn (quarter speed) and in what direction (left or right), so the robot will move forward in an arc as it turns. To turn in place, make y=0.
To overcome the mass and friction of the robot it takes a little bit of the low-end power, so maybe 20% (.2) of the forward power will simply get the robot moving slightly (depends on the robot).
To turn the opposite way leave y alone and make x negative, i.e., x=-0.25
Make y negative to backup while turning.
If you use Tank Drive instead of Arcade, then you might reverse the two inputs to get the opposite effect, but the inputs would typically represent two y joysticks, rather than the single joystick of Arcade. In autonomous of course there are no joysticks, but many people still like to think of it as if a driver were controlling the robot.
Unread 22-11-2011, 10:08
Originally Posted by Mark McLeod View Post
The x value tells Arcade to move at one quarter speed while the y tells it how much to turn (half speed)
I think you have the x and y interchanged?
http://www.chiefdelphi.com/forums/at...d=13219745 12
Unread 22-11-2011, 10:44
Yes, thanks. I made that and other corrections.
I'm a bit distracted by the NASA Grant emails flying around this morning.
Unread 23-11-2011, 10:12
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
so, which one is the forward movement? x or y?
Unread 23-11-2011, 10:17
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
x axis is for movement left and right,
y axis is for movement up and down
"A team back in training !"
Unread 28-11-2011, 06:54
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
oh ok, so it is just like a graph. Thanks, got it now.
Unread 28-11-2011, 12:05
Rather then changing both x and y at the same time, it would have been better to only change one value while keeping the other the same. I would probably try five different tests (see below). That may seem like a lot, but it allows you to fully characterize the behavior and is a lot faster then changing multiple values at once and guessing which one caused what change. Once you've done those, you should be able to predict what would happen for any other combination.
x=0, y=0
x=0.25, y=0
x=-0.25, y=0
x=0, y=0.25
x=0, y=-0.25
