Go to Post It goes to show how a FIRST team is not one person but a complex codependence of people who are all striving to meet the same goal. - Bill_Hancoc [more]
Unread 29-12-2011, 20:07
Andrew Lawrence
Posts: n/a
Disadvantages of swerve/crab
I love swerve drives, and by the looks of them a well implemented one SEEMS like the best drive train in FIRST. So my question is: What are the disadvantages of swerve? I don't mean like it's more difficult to build, or it's heavier than other drives or harder to program, but disadvantages in performance.
Unread 29-12-2011, 20:18
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Disadvantages of swerve/crab
Complexity of the hardware.
Unread 30-12-2011, 00:39
AdamHeard's Avatar
Lead Mentor
Which is nothing compared to complexity of software/control philosophy.
FRC #1836 (MilkenKnights)
Simply, there is none. An independent coaxial swerve, programmed perfectly, will be the best drive out there. The one performance disadvantage, is that if one module brakes, your whole drive system is down(this applies to all drive systems, except wcd and variations). However, the resources needed to get to this point are tremendous, and without planning and time, the benefits are nullified.
Unread 29-12-2011, 20:23
LeelandS's Avatar
LeelandS LeelandS is offline
Robots don't quit, and neither do I
AKA: Leeland
FRC #1405 (Finney Falcons)
Team Role: Tactician
LeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond repute
Competitively, Swerve is, perhaps, the best ALL AROUND drive train in FIRST. All around meaning it follows the old saying "Jack of all trades, master of none."
Swerve is so much desired because it offers the omni-directional movement of Mechanums, without relying on wheel slip and thus, is not as easily pushed. 4 Wheel Swerve will offer, more or less. similar power as a 4 wheel drive. Which is not particularly excessive, but well enough.
In addition, Swerve won't outrun a lot of drive systems. It's going to rely on that omni-directional movement to cut out the time used in turning to make up for the lack of excessive speed. Unless you're 973 using Emperor Swerve, you're not going to be moving at very fast speeds. That's going to be the result
Average speed + average power + omni-directional movement = one very effective drive system. But it will not handle drive systems that excel in power or speed very well. That is, of course, based on an average Swerve. Some teams who have become very well versed in Swerve drive can overcome these shortfalls and create a drive system with great power and speed. But your average Swerve will boast a decent level of speed and power, not a wealth of either.
Edit: And, yes, as many are mentioning, Swerve is very prone to failure. And recovering from a failure in a Swerve module is no easy task.
Edit-Edit: I apologize for my bad terming. I'm being quite unclear about a lot of things. Apologies, again.
Disclaimer: I'm no expert. Don't take my word as law.
My heart will forever lie with SparX
1126: 2008 - 2011; Where it All Began.
1405: 2013 - Present; A Wanderer is Born.
Work hard, play hard. And maybe someday...
Last edited by LeelandS : 29-12-2011 at 20:42. Reason: Clarifying. I'm not terming very well.
Unread 29-12-2011, 20:28
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Many many more possible points of failure.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 29-12-2011, 20:31
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
[mecanum_troll] Mecanum wheels can drive in circles around swerve [/mecanum_troll]
Unread 29-12-2011, 20:29
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
It's also likely to be devastated by a single part failure. If a module freezes up for any reason (even if it's perfect, there's a chance of damage) then the drive is almost useless.
Not that any other drivetrain is free of such problems.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Swerve is so much desired because it offers the omni-directional movement of Mechanums, without relying on wheel slip and thus, is not as easily pushed. However, that in no way means the average Swerve can push. Your standard 4 wheel Swerve will lose a pushing match against most decently done 6 Wheel Drive Systems.
While you say that swerve does not have the same "power" as a 6 wheel, I'm not sure what you are referring to, as they will have the same power, assuming they have the same traction.
Unread 29-12-2011, 20:39
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
*Most swerves have one motor per wheel assembly. This means that when they are being pushed and are forced up on 2 wheels they have half the power to push back.
*118 had some wicked swerves specifically 2005 and 2007 are well known for the most powerful wicked fast drives ever. However, it could not rotate so to compensate they put their entire manipulator assembly on a turret.
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 29-12-2011, 20:32
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
These points aren't necessarily 100% accurate. Both of these will vary with the implementation of the swerve and the drive it's being compared to.
Pushing power is defined by the robots over all weight and wheel configuration, being a swerve doesn't really change much here - other than the fact that a 'unicorn swerve' (or any swerve with independently powered modules like 111's) has the issue of losing pushing power if one or more of the wheels lose the ground as the motor's power is wasted and the weight on the driven wheels will now be less - this is an issue that any drive with independent wheels can encounter.
For examples of fast swerves other than 973's Emperor Swerve, reference either 16 (In any year, but 2008 or 2011 would be best) or 148 (2008).
-Dustin Benedict
Unread 29-12-2011, 20:36
Pushing power is defined by the robots over all weight and wheel configuration, being a swerve doesn't really change much here - other than the fact that a 'unicorn swerve' has the issue of losing pushing power if one or more of the wheels lose the ground as the motor's power is wasted and the weight on the driven wheels will now be less - this is an issue that any drive with independent wheels can encounter.
In addition to this- you (leland) keep saying "your standard swerve drive" but what are you defining that as?
The pushing thing can be whatever depending on the drive gearbox just as any other drivetrain can be. 2 speed solves all problems you mentioned.
Chris is me's Avatar
AKA: Pinecone
How many of you guys have built and tested a swerve and compared it to a six wheel?
Unread 29-12-2011, 21:06
sgreco's Avatar
AKA: Steven Greco
FRC #2079
2079 has kind of done this. We didn't really test any quantitative data, but we have run both in comparison during driver tryouts. The general sentiment from our drivers was that swerve is not as intuitive to drive (it does depend on the programming, but the programming is something that is really hard to get right).
And just from experience of doing both, 2079's 2nd gen swerve broke with much higher frequency than our 1st gen 6WD. Swerve requires a lot more fine tuning before you get it "right".
All 6 wheel drives have a zero turn radius (or at least most). Only well designed swerve drives can do this.
Both designs are good if implemented well, swerve just seems to require more effort to make it work well.
Unread 29-12-2011, 21:54
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
I'd say one big disadvantage is that it isn't very practical to implement a two speed drivetrain with swerve. You'd need to pick one multi purpose speed and gear for that, making your robot prone to being pushed around by a 2-speed 6WD bot.
