Go to Post I used to wonder if the FRC staff would read the CD game hint posts and just laugh to themselves..now I know they do. - rachelholladay [more]
Unread 31-12-2011, 16:47
nnfuller's Avatar
nnfuller nnfuller is offline
AKA: Alumni
FRC #2733 (Pigmice)
nnfuller is on a distinguished road
Casters vs. Unpowered Omni wheels
So I have been looking at a lot of older robots for inspiration for a new chassis design before build season and I was wondering if any veterans could tell me why we don't see casters anymore. I have seen a large number of robots with unpowered omnis, but no casters... Why do you think this is, becase from where I'm standing...
Casters
Pros:
  • Self Contained
  • Pre Assembled
  • Bolt and Go Simple
  • Smooth Ride
Cons:
  • Have a "Direction" that must be overcome
  • Cannot be Powered
Unread 31-12-2011, 16:49
Joining the 900 Meme Team
FRC #0079
Re: Casters vs. Unpowered Omni wheels
Casters
Pros:
  • Self Contained
  • Pre Assembled
  • Smooth Ride
Cons:
  • Cannot be Powered
Because casters tend to change the direction randomly depending on how they start. Ask any FLL team.
Unread 31-12-2011, 17:03
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
casters tip easily. no matter what direction they are pushed, they always pu the pivot point (the axle) in a bad position in terms of stability.
not that casters never work, but that i have only seen one robot ever that used them well , and that was in a picture (some veterans around here would be able to guess it). however, I have seen many examples where casters were a complete failure.
Unread 31-12-2011, 17:07
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
We used casters on our 2008 robot for the front wheels. They worked pretty well.
Unread 31-12-2011, 17:12
davepowers's Avatar
davepowers davepowers is offline
Currently dreaming about robots
AKA: Danger Dave
FRC #1687 (Highlander Robotics)
davepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud of
GUS' very first year we used casters, they worked for us, sort of. I do remember the robot did a very good job of not going straight, that might not have been the casters though. There were a few problems with turning, sometimes the casters would turn a way they shouldn't, but it would always push through.
-Dave
David Powers - Deans List Finalist - WPI 17' - Bleed True Clothing
1999-xxxx FRC228, GUS Robotics Inc.
2013-xxxx FRC1678, Highlander Robotics
Unread 31-12-2011, 17:51
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
We used casters early on until 2005. We now have a hard and fast rule, no casters allowed on the robot, ever.
Unread 03-01-2012, 20:47
pfreivald's Avatar
AKA: Patrick Freivald
We used them in Rack and Roll. It remains to this day the most disastrous engineering decision we've ever made. (And we've made some doozies!)
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 07-01-2012, 21:46
tlivingd's Avatar
tlivingd tlivingd is offline
FRC #4095
tlivingd will become famous soon enough
We used them in 1997 and I was a driver. They work fairly well if the rest of the machine was designed to work that way and the use a more sweeping style of driving than sudden direction changes. We even had mixed control with single joystick instead of dual joystick tank drive.
Our machine was a front wheel drive tail dragger. It had a forward heavy CG and would scoop tubes and reach forward.
The event was Toroid Terror and the event was in a hexagon with a center mounted goal.
The year prior we used a 2wd center mounted with solid pads instead of casters in the 4 corners. it was tank driven and was fine, just rocked a little.
However in this years event there is no way they would work with the ramps/tables.
Nate
Mentor Team #4095 Team RoXI
Student Team #13 BioBeast
Billfred's Avatar
Billfred Billfred is offline
1293 used casters its first two years. The first robot (whose autonomous was just timing and held breath) would be thrown off-course if the casters weren't right but was otherwise underpowered enough that it wasn't a huge issue. The second one (powered by CIMs) verged on uncontrollable on the field, easily the weakest link in its design. They haven't looked back, going with treads ('07, '10), N-wheel-drive ('06, '09, '11), or mecanum ('08).
2815's always driven all the wheels on the floor, so no experience there. (I would want to know why someone wouldn't power an omniwheel; there are certainly some scenarios, but I can't see those scenarios being anything but a teensy minority.)
Unread 31-12-2011, 18:05
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
We used four casters on the corners, and two powered wheels centered on the sides. Using a tank drive program it worked quite well.
Pros:
1. Cheap!
2. They work!
Cons:
1. Wobble while they orient themselves
2. Look lame
Unread 31-12-2011, 18:10
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Casters probably make sense for a drive like this.
Not that we have experience with casters - we've used omnis when we had to, and we powered them like 2815. Why do anything else?
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 01-01-2012, 01:55
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
This was a Fully Omni-Directional robot that successfully worked during competition.
It was very successful and arguable the best robot in 2000. Still we have to remember that the competition has since changed, and drive capabilities have greatly improved.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 01-01-2012, 02:10
Chris is me's Avatar
AKA: Pinecone
Originally Posted by Marc S. View Post
This was the first FIRST Fully Omni-Directional robot to successfully work during competition.
Slight correction: 47 had an omni-directional robot in 1998 that successfully worked quite well. They won three regionals that year - I don't think there were more than a dozen.
Unread 01-01-2012, 02:55
Marc S.'s Avatar
AKA: Adversity
Here's one of there matches. Oh though your right, upon further inspection they did build one in 1998(back when there were only 5 regionals).
Unread 01-01-2012, 10:22
Casters don't work for autonomous since they have a mind of their own. They are simply a bad idea for any game that has ramps or some other drive over hindrance. They generally do not turn within their own radius so the robot will veer of course. And...have you never driven a cart at a store where the fronts wobble?
