Imaging tool for the new 4-slot cRIO
Our team got the new 4-slot cRIO for this season. I thought I would prep the cRIO and load some test code to check it out. But the 2011 imaging tool does not see the device. I was told I need the new 2012 imaging tool that will come with the KoP this season. I was also told some beta teams may have gotten it already. If so, would somebody in the beta teams care to send the tool to me?
Thanks. |
Re: Imaging tool for the new 4-slot cRIO
The old imaging tool will not recognize the new 4-slot cRio, and if it did you would not have an appropriate image, so you would be unable to write code for it. The new imaging tool, new image, and new software libraries that the Beta Test teams have been playing with will be made available at kickoff (in just a week!), so you'll just have to wait for now. It is against the Beta Test teams agreement they signed in October to distribute the software they have been testing (and it's not even the final version anyway).
That's what I suspected. Thanks for the information.
So, how do we image the new cRio? I'm not finding the needed software in the new release.
I believe it should be on the labview credit card flash drive. FRC tools are what you want (so option 2)
I found it; it's installed only as part of the 2012 utilities update from NI's website.
#7
I am attempting to image the new 4-slot cRIO and it failed with the following message:
Unable to complete operation because of unexpected error:
Error -2147220304 occurred at nisyscfg.lvlib:Restart.vi:1
Possible reason(s):
NI System Configuration: (Hex 0x800404B0) Timeout while waiting for reboot. System is offline.
Complete call chain:
ConfigUtility.lvlib:2012_FormatSystem.vi
ConfigUtility.lvlib:ReImageTarget.vi
ConfigUtility.lvlib:Dialog.vi
The configuration I picked was: - Wind River Workbench (C++) - Enable NetConsole - 2CAN Ethernet Bridge (not V2 though) - Format Controller with Image FRC_2012_v43.zip - Team ID: 492 |
#9
On some computers it is currently necessary to disable all unused network interfaces except for the one connected to the cRIO. Also, make sure that the subnet mask for the PC NIC is set as specified. I believe it is supposed to be 255.255.255.0, rather than the wide open one. Finally, it is sometimes useful to plug the cRIO and PC into a switch so that the PC NIC doesn't go down while the cRIO reboots.
This was still being investigated late into the beta, but was rather uncommon, so please respond with anything that improved your symptoms. Greg McKaskle |
#10
I am getting the same error but trying to format it for Java..any help would be appreciated
#11
Joe |
