Drive Systems
What drive systems are people thinking about using for this game? It looks like a 6 wheel drive will be best (because of the barrier), but I can see ways to use a mecanum or swerve drive (using the bridge).
Re: Drive Systems
A lot of teams are going to go mecanum because of the existence of protected zone, but defense will be aggressive in preventing them from getting there.
I can see 4 wheel tank being viable due to the fact it makes getting ground clearance for the bump easier (see 330's 2010 bot) as well as working on widebody robots. As with nearly any game, 6 wheel tank is viable and will be the most commonly used drive, and since the kitbot is 6 wheel drop center, FIRST engineers thought it could play the game. |
Re: Drive Systems
I'm curious if anyone is going to try to build a drive train to actually circumvent the barrier. The only things I can think of to do that would be either rather large wheels or a tread drive (after actually seeing the barrier, normal wheels will likely be an "improbability"
). Then again, the rules are strict enough in regard to passing over the balance boards (G25, G28, G29) that I doubt there will be a need to go over the barrier. Our team has been developing a 6-wheel drive system that we are pretty happy with, because of the increased mobility over the 4-wheel. However, 4-wheel drives will have a fine time navigating the field as well, I think. |
Re: Drive Systems
Re: Drive Systems
Re: Drive Systems
You could always ask the GDC to be certain, but I can only think of one wheel restriction rule (back in '09). |
#7
Re: Drive Systems
How? Watch SVR in 11 weeks and find out! |
#8
Re: Drive Systems
Re: Drive Systems
Team 610 in 2010 had ~10" pneumatic wheeled 6WD; the middle one rose and lowered so that they had an easier time with the bump. I'll try to find a video, but most of them are low res taken from far away. Anyone have a picture of it? Still my favorite robot of all time.
#10
Re: Drive Systems
http://frc-designs.com/html/CAD_2010.html |
#11
Re: Drive Systems
This was posted in a different forum. It's a really cool way to drive the robot, but i'm not completely sure how effective it would be for this years game.
http://youtu.be/uaT7M3Nwj7c |
#12
Re: Drive Systems
Our team is also coming up with ways to jump the bump, but I'm actually surprised that people think mecanum will be used by a lot of teams. HDPE floors? Bumps? Bridges? Those will not be nice to your poor Swiss wheels.
#13
Re: Drive Systems
Have 2 pneumatic cylinders between the front and middle wheels, pointing down. Then, at the press of a button, the shoot out for a second and come back in, lifting your robot into the air, and giving it room to get over the bump.
#14
Re: Drive Systems
Who are you, Speed Racer? Do you also have cutter blades, a bulletproof canopy and a homing pigeon? Oh no, the homing pigeon is like a minibot! Arrrrrrghfuuuuuu!
#15
Re: Drive Systems
I think octocanum with barrier assist sounds about right for this one...
