Go to Post Winning is important. Learning is important. Inspiring students is important. Teaching Students is important. Figuring out how to do all of these at the same time, in my opinion, is the meaning of FIRST. - Justin Montois [more]
Unread 07-01-2012, 21:34
ehlochbr ehlochbr is offline
FRC #2990
ehlochbr is an unknown quantity at this point
2012 FRC Labview thumb drive doesn't work
Hi,
We just got our KOP today and I found the labview update thumbdrive and plugged it into my laptop and nothing happened. I tried to explore the thumb drive and my laptops doesn't show anything on it. Am I doing something wrong?
My license is about to expire and I need to renew it quickly!!
Is the update online? I've installed the online updates that I've found and Labview still says my license will expire is a week.
Thanks!!
Eric
Unread 07-01-2012, 21:41
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: 2012 FRC Labview thumb drive doesn't work
Originally Posted by ehlochbr View Post
Hi,
Thanks!!
Eric
We found our flashdrive to be very finicky as to how it was plugged in. It had to be just right, and it couldn't move at all for it to retain its connection. I'd start by double checking the drive is plugged in and your computer is recognising it.
Also, I think (somebody correct me if I'm wrong) that you could just download LV2011, use the serial number provided, and install the updates. I think that should also work...
Unread 07-01-2012, 21:45
The thumb drive for LV actually contains two volumes, one empty, and the other with an installer for the 2011 version of LV.
Please check for the existence of the other drive.
Greg McKaskle
Unread 08-01-2012, 16:05
Ivan Helmrich's Avatar
Ivan Helmrich Ivan Helmrich is offline
FRC #1775 (Tigerbytes)
Ivan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to behold
I tried to install LV on two systems today. On my XP laptop, it worked fine. On my Vista, nothing showed up on the drive. I was only able to see the one empty volume. Maybe try on another system.
Ivan
“The knowledge of what is relevant, what is not and the skill to cleverly work around or approximate solutions is the essence of engineering.” - James C. King
Unread 08-01-2012, 16:53
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
we found that plugging USB flash drives into the USB hub first, and then plugging the hub into the classmate works much better.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 08-01-2012, 21:53
ChaosX73 ChaosX73 is offline
AKA: Ryan Harrison
FRC #2338 (Gear it Forward)
ChaosX73 is a glorious beacon of lightChaosX73 is a glorious beacon of lightChaosX73 is a glorious beacon of lightChaosX73 is a glorious beacon of lightChaosX73 is a glorious beacon of light
I don't know if I have the correct flashdrive (im running windows 7) it's the green and white one that says 2012 image, E09. I plugged it into my computer, but no automatic execution starts. I can view the contents of the flashdrive, and it has the folders boot, EFI, and sources. It also has some documents outside of these three folders, bcdboot.exe, bootmgr, DPREP.INP, E09_2012_MASTER_09112011.wim, HIDESYSTEM.TXT, imagex.exe, RestoreDS.cmd.
I tried running both of the .exe files but they simply opened up cmds that immediately close and I can't see what they say. What is this thing and why is it giving me troubles?
Unread 08-01-2012, 22:05
That USB drive is used to reimage E09 laptops. You need to mount it during the BIOS launch if you intend to use it.
Greg McKaskle
Unread 09-01-2012, 12:57
FRC #2990
We got ours to work! I had to turn off autoplay in my control panel because my computer was thinking that I wanted to explore the thumb drive so it was "autoplaying" directly to the windows explorer. If you plug in the thumbdrive and don't see the option to select autorun with a labview icon next to it, try turning off autoplay. Good luck and thanks for all the resposes.
Unread 11-01-2012, 09:42
dkearle's Avatar
dkearle dkearle is offline
Dianne
FRC #1280 (Ragin' C-Biscuits)
dkearle is an unknown quantity at this point
The correct USB drive used to install the National Instruments LabView and the FRC Tools is contained in a white and orange envelope that looks more like it contains a CD until you open it. The envelope is labeled "NI Software for FRC 2012". Inside is a very flat USB drive labeled NI LabView for FRC Software Install Drive.
Last edited by dkearle : 11-01-2012 at 09:57. Reason: Added additional clarification.
