Driver Station Image Problem
Team 2435 - Lawton, OK
When we try to reimage the Clasmate Driver Station with the USB stick we received in the KOP, we get a Disk Read error. BTW we are a veteran team so we got the E09 stick. Anyone else having this problem? |
Re: Driver Station Image Problem
u r not alone
http://www.chiefdelphi.com/forums/sh...threadid=99363 |
Do not change your disk priority to the USB first, or it will give you the disk read error.
You have to hit the F11/F12 key on the 2GO boot screen and select the USB device. There are two, and I'm not exactly sure which one to select, so try both. You will know when it works. PS: Please post when you figure it out which USB option you chose. -Eagle Engineering |
