Go to Post Do not interrupt, do not defend yourself - just listen. After they are done, be sure to thank them for their honest feedback, and close the books. Arguing or defending is not how to accept feedback. - DonRotolo [more]
Unread 07-01-2012, 22:18
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Wheels contacting the ground
I was wondering if it is OK to have the wheels of the robot not contacting the ground.
In a game where both means of scoring rely on good, reliable positioning it might be advantageous to lift the robot onto braces, so it can't be knocked around, or slide.
Can't find any rules against it, so long as it does not damage the arena, or require insane power sources.
Unread 07-01-2012, 22:25
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: Wheels contacting the ground
[R06] Traction devices may not have surface features such as metal, sandpaper, hard plastic studs, cleats, or other attachments. Traction devices include all parts of the Robot that are designed to transmit any propulsive and/or braking forces between the Robot and the Court.
Looks okay to me, as long as you don't use any of the above prohibited items...
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 07-01-2012, 22:28
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
That rule is in place to prevent carpet damage. One year, there was a robot that used file cards as feet and also shredded carpet. That no longer happens.
If your idea doesn't do that, it should be okay.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 07-01-2012, 22:43
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
But since the key is HDPE, not carpet....
