Go to Post I WANT MY POOF BALLS! - Cyber Punk 234 [more]
Unread 08-01-2012, 14:47
ghandler94 ghandler94 is offline
FRC #3504
ghandler94 is an unknown quantity at this point
Using a Color Sensor to Shoot
Having played basketball myself, the two most important assets to a good shooter are being square to the basket and having proper arc on your shot. Very rarely do players utilize the back board to make a shot, hence a "swish" where the ball touches neither the backboard nor the rim. In human version of basketball, this is the most efficient way to shoot, particularly with defense.
Our team has found it an obvious idea to have the shooting be autonomous, because human error would play far too much of a part in the shooting.
I had the idea of having the autonomous part be sensing the color of the rim. Since the rim is a circle, this avoids having to determine the robot's angle in relation to the hoop. From sensing where the rim is, the Kinect could determine distance, plug that into a formula and change the angle of the shooting mechanism to determine the arc of the ball.
Coming from a newby, is this a feasible idea? I see making the angle of the shooting mechanism as being feasible, but I am not sure about the programming?
Thoughts? Thoughts on shooting ideas as a whole?
Unread 08-01-2012, 15:07
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Using a Color Sensor to Shoot
I don't think color sensors work from that far. Even if they do, it would be hard differentiating between the different baskets. And I don't think color sensors give you position. Camera is the way to do it.
